You cant just swap over like this..
D8 is on the 11amp circuit
D9 an D10 are on the 5amp circuit
The 5amp poly fuse will just heat up and probably burn.
The PCB tracks in general are not big enough for 11amp, so re wiring is also not straight forward.
You can rewire it if you use really think wires to assist the copper tracks on both -ve and +ve lines and swap the +ve to the 11amp side.
Personally I would try fix the 11amp circuit. Replace the blown tracks with thick wires. (remember 11 amp !)
Edited 1 time(s). Last edit at 08/19/2014 06:58AM by Dust.
