I have finally finish all setup calibration etc' on my kossel mini printer.
I've never printed before so sorry for the beginner q'..
I have found several cubes & used Slic3r to convert the stl to gcode.
Each of them start to print in different location according to the map (when loading the gcode output of the Slic3r into pronterface).
In my last attempt the printer moved all the way to MAX RADIUS than stopped.. only than I've noticed that the part was about to be printed outside the bed.
So.. I'm guessing I'm doing something wrong.
How can I center the printer gcode to my 170[mm] bed?
Could someone kindly direct me to a simple test cube?
I have a heated bed (finally working
should I use kapton tape on top of the bed glass or heated bed will be ok? [I'm printing with ABS]
Best regards.
