Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers November 06, 2014 03:06PM |
Radio Frequency engineers would tend to use shielded cables due to their heightened awareness of these issues, no? While flattened by your complement, I am in fact not an RF engineer. So I would keep to the electronics and stay away from the crystal ball.Quote
cozmicray
But sounds like you are RF engineer and will use any wire that is available?
Ok, no problem. What size diameter do you recommend I should use to ensure I get the precision I need based on the 1500x800x700mm specification? And in the interest in keeping the weight down, would there be any harm in using the thinner rods on the shorter axis; in my case the 700mm Y-axis?Quote
cozmicray
Again I'll say testing showed 12mm diameter 36" in length solid rods flexes a lot. up/down, side to side, even under tension!!!!!
Yeah, I think the Bowden tube is probably going to be a pain due to the oozing, and extra retraction; I can just imagine. And I kinda want a 2 extruder head to print different colours, so that’s extra weight again if I don’t use a Bowden design. I’m still undecided about the use of a Bowden design due to the retraction and oozing issues. Maybe I could use smaller motors on a duel & direct setup? Make use of 3d printed gears maybe? I’d like to hear some thoughts on that.Quote
cosmicray
If you are going to use a Bowden --- my condolences and be prepared for MAX frustration!!
Ok great… I cant see why people don’t just jump in with 35V at all times?Quote
cosmicray
The pololu drivers can handle 8-35 V and 1 amp per phase.
Voltage
The higher the output voltage from the driver, the higher is the level of torque versus speed.
You can think of the voltage as the driver of the current. The higher the voltage,
the faster will the current in the windings reach its new target value from one step to the next.
Therefore it is conceivable why a higher voltage will result in better speed performance.
Yeah, I’ve seen a video where a man burns his finger on a faulty mosfet that was so hot it had worked loose from its 3 solder points. And the one he touched had a decent heatsink! So I think I’ll be getting a heatsink for mine.Quote
cosmicray
The extruder hotend and heated bed will pull more on your RAMPS mosfets than the motors!
With your tight RAMPS case --- the components will be toasted real quick.
Cosmic Ray, your input has been invaluable, but these snide comments throughout your posts are wearing thin, and you’re making a bit of a dick of yourself, and none of the other contributors make these type of comments. Other viewers will see you clearly know your stuff, and will be left disheartened to find that the good information they have just read has come from someone who enjoys putting others down; others who don’t have the skill set you have. For your information, I do indeed use google, and have done a lot of research in to this project. However, I don’t take what I read as gospel because the internet is full of Cosmicray’s and I will always continue to confirm information from several sources before putting my family at risk by powering up a ‘reprap style’ system of this magnitude with full confidence that my family will not suffer as a result of my projects. If you don’t like repeating yourself, or if you don’t like typing information that ‘you’ could find on google in just moments, then please keep it to yourself if it troubles you so much that you have to make a childish close to your messages, since I would rather go without the information than trouble you that much, and continue to allow you to make a dick of yourself on public viewable forums. However, if you can possibly find it within yourself to continue providing this priceless information as you have been, then please do so in a polite and decent fashion.Quote
cosmicray
Just keep bumbling around -- NOT doing some study from info on the web
Hi Jaguarking, This is good information! I’m hoping to choose two hot ends that have an easy to change nozzle design so that on larger prints that require less precision. I’m interested to hear about the all-metal hot ends you mentioned if you have some more information that would be great!Quote
jaguarking11
One thing I would like to add. Printing with a large nozzle certainly helps a bunch. I accidentally bored my jhead to 1.54mm and tried to print with it anyway. After some fiddling it will work. You need a geared extruder with a ratio of 2:1 or so to keep the motor happy and that spool spinning fast.
Next up I am replacing the hot end with a all metal design. I will be boring one of my nozzles to 1mm or so and use that for higher speed large prints, and keep the variety of nozzles I have at stock sizes ranging from .3mm to .5mm..... I think having a large printer you need a larger nozzle unless you want to print small things in high detail ~1mm nozzle should allow for layer thickness in the .5-.8mm range. If you want to use 1.5mm nozzle or even 2mm nozzle I would suggest 3mm filament. You also need to specify the wall thickness in a 1:1 with the nozzle size, I found it helped preserve the dimensions, which also means you should keep an eye out on designs using parts smaller than your nozzle.
Good points raised here. I won’t be printing ABS at all, I just don’t see the point; I hate the stuff. So the unit will be open on all sides allowing the motors to be a little cooler, and the ramps box will therefore be pulling in fresh air to cool itself down.Quote
cosmicray
Your huge prints will require days of printing
Will your electronics, motors last for days without melting?
ABS printers a usually enclosed -- keeping production chamber warm
--- are you going to put your printer in a huge powder coating oven?
I really don’t want to use any gearing made by myself, I’d rather get the correct motor for the task than engineer it to work; it feels a little “make do”. Even though, that probably engineering at its finestQuote
jaguarking11
Not necessarily, he could use geared motors and vslot grooves to build something bigger. Or even better he could buy some large and small gt2 pulleys and create his own belt driven gearbox, giving him proper ratios to double the torque of the motors used, at the expense of some speed, but certainly not 1/2 the speed. Nema 23's are available, so are more powerful stepper drivers. Engineering is about problem solving. Sometimes you wont know how it works until you try. My printer is not in the grand scale his is, but It is a large 4.5 feet off the ground, working with nema 17's.... rather well may I add. Certain things need to get larger, other things can stay the same.
Hi Mariechuria, welcome to the discussion. For someone new you’ve provided some great input!Quote
mariechuria
If you are printing ABS, there will most likely be a need to print big parts in a heated build chamber and the design of the whole system should be taking that into account
[T]here is a high current, affordable, Pololu driver-compatible stepper motor driver called Powerlolu.
Also, if you have not, check out the large format printer from grassrootsengineering: [www.grassrootsengineering.com]
And look at this video of it in action, printing a kayak in a heated chamber: [www.youtube.com]
Can it really be built cheaply while still having appropriate safety standards and a build quality that is making the machine truly reliable?
What about resuming prints? I have not read a lot about this and I wonder what sort of options might be existing to print single large parts with pausing.
So really... I think building such a printer is doable... when you think smart even with a reasonable budget. The real question is- Is it really usable? And will it really be what you are looking for?
Hi there Paul, thanks for joining the cause.Quote
Paul Wanamaker
For larger jobs there needs to be a filament-out sensor and firmware that will detect it, or you can set something in your slicer to pause at a certain height (Cura has this under Extensions).
I know Repetier is planning on supporting a filament out sensor in future, not sure if others have it! I am planning on some jobs that will take more than 1kg of filament, I may combine rolls.
You have not intruded, you’ve brought some valuable information to the table in a more polite format than some others have.Quote
dclarkm
I'll return to my lurking and learning....for now. Again, sorry to intrude....please, continue.
OMFG, why the hell didn’t I think of this…. Phenomenal idea…. AND it looks nice!!!Quote
jaguarking11
One thing worth noting. As long as the wires for the end stops are not moving much, you can use cat5 cable to eliminate the cross talk.
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers November 06, 2014 03:20PM |
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers November 06, 2014 03:21PM |
munchit1
hi all, new to the forum but very intrested so far, i'm also finding similar 'all about it bumf' that actualy tells zilch about actualy doing it.
ohh.. and i'm at a similar point on my 1000mm x 500x500mm print area lol.
now so far i was under the impresion the nema 17's would run a horizontal axis weather it was 10mm or 1000mm? theres only the time diference of running the distance?
the Z axis, if it drops the print surface down then so much power isnt needed surely? especialy when the forces are spread over turning 2 or 4 screw threads? (just needs enough to raise the empty bed).
multi motor systems, isnt there ways of adding aditional systems run by the controller? even with seperate power supply's per group maybe? a seperate heater bed sytstem would be very easily acheaved by simpley purchasing temperature control circuits and running them as a seperate system.(theres no real timing to the other motors going on is there?)
it's made me stop and think tbh...as in stop dead, i need it to go in one hit,and so far its sounding like nehhh it wont.
side issue reguarding vibrasions, whys no one useing wood? i came across the wood verses the metals in quodcopter building, the wood helps absorb vibration as well as sound, so am i missing the point on 'vibrasions'? is it the actual stepper acceleration/deceleration 'vibrasions' were talking about? (incorperating missed steps perhaps?).
and my final note is, the extruder system is as fast as it will go any ways....so thats where to 'time to' for the rest of the gear..... i'm a noob guys patients please lol.
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers November 06, 2014 04:08PM |
Paul Wanamaker
Heating the chamber is no problem, the heated bed will do that all by itself nicely.
munchit1
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers November 06, 2014 04:19PM |
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers November 06, 2014 04:34PM |
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers November 06, 2014 04:37PM |
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers November 06, 2014 04:40PM |
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers November 06, 2014 04:42PM |
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers November 06, 2014 04:43PM |
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers November 06, 2014 04:57PM |
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers November 06, 2014 09:24PM |
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers November 06, 2014 10:17PM |
Admin Registered: 12 years ago Posts: 1,063 |
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers November 07, 2014 03:01AM |
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers November 07, 2014 03:49AM |
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers November 07, 2014 07:51AM |
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers November 07, 2014 08:22AM |
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers December 31, 2014 08:27PM |
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers January 05, 2015 01:45PM |
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers January 07, 2015 04:34AM |
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers January 07, 2015 01:55PM |
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers January 08, 2015 11:37PM |
Paul Wanamaker
Concerning a filament out sensor as discussed above:
This is now easily doable. I've just upgraded to a Smoothieboard, and there is a feature for this, and also a pause/resume button, if you want to switch filament. It can move the print head out of the way, retract the filament, etc (whatever g-codes you tell it to do). It can then resume where it left off. I've not done it yet, but the functionality is there. I suppose you'd either need to tell the printer not to turn off the motors, or to home afterwards... I'm loving this board, so many problems gone.
