Z axis homes but doesn't move otherwise November 05, 2014 04:27AM |
Re: Z axis homes but doesn't move otherwise November 05, 2014 05:01AM |
ShadowE
I've been going mad trying to figure out why it is exhibiting this behaviour.
The z axis homes but when I try to get it to move using the arrows around the target in Pronterface it doesn't move at all. Sometimes it gives a bit of a jerk but doesn't actually move.
I have a Prusa Mendel i2 and I'm using RAMPS 1.4 with stepstick drivers. I'm using Slic3r and Pronterface to operate the printer. The Load Voltage to the driver is 12.34 V and the logic supply voltage is 4.97 V. The current is within the recommended range.
I tried to see if it is the driver issue by using other drivers but the same problem occurs. When I connect the z axis motors to the y axis driver they work as they should.
All the other drivers and motors are working perfectly.
I'm at the end of my tether. Anyone have any ideas?
Re: Z axis homes but doesn't move otherwise November 05, 2014 05:11AM |
Re: Z axis homes but doesn't move otherwise November 05, 2014 05:39AM |
ShadowE
M119 command returns this:
>>M119
SENDING:M119
x_min:L y_min:L z_min:H z_max:H
To invert the max endstop do I have to change it in configuration.h? Which lines should i bee looking at?
Re: Z axis homes but doesn't move otherwise November 10, 2014 01:49AM |
Re: Z axis homes but doesn't move otherwise November 10, 2014 02:17AM |
Admin Registered: 13 years ago Posts: 7,005 |
Re: Z axis homes but doesn't move otherwise November 10, 2014 02:39AM |
Re: Z axis homes but doesn't move otherwise November 10, 2014 02:40AM |
