Pronterface seems to react wrongly to manual extrusion command? November 10, 2014 08:38AM |
Re: Pronterface seems to react wrongly to manual extrusion command? November 10, 2014 09:34PM |
Re: Pronterface seems to react wrongly to manual extrusion command? November 11, 2014 05:34AM |
Re: Pronterface seems to react wrongly to manual extrusion command? November 11, 2014 07:48PM |
Re: Pronterface seems to react wrongly to manual extrusion command? November 12, 2014 03:25AM |
Re: Pronterface seems to react wrongly to manual extrusion command? November 12, 2014 04:26AM |
homecore
Hey Sungod3k,
There is nothing wrong with the frame. Let me put it this way:
I can leave the pronterface field on the default 5mm and press the 'extrude button' 4 times. The result = 20mm
I could also fill in 20mm and press the button once. The result seems to be only 5mm
==> the results are not the same, it seems like pronterface remembers the first value used and ignores the second value I fill in.
Re: Pronterface seems to react wrongly to manual extrusion command? November 13, 2014 03:27AM |
Admin Registered: 13 years ago Posts: 7,008 |
