X-axis optical endstop failure January 06, 2015 06:28PM |
//#define ENDSTOPPULLUPS const bool ENDSTOPS_INVERTING = false; const bool DISABLE_X = true; const bool DISABLE_Y = true; const bool DISABLE_Z = true; const bool DISABLE_E = false; const bool INVERT_X_DIR = false; const bool INVERT_Y_DIR = false; const bool INVERT_Z_DIR = false; const bool INVERT_E_DIR = false; #define X_HOME_DIR -1 #define Y_HOME_DIR -1 #define Z_HOME_DIR -1 const bool min_software_endstops = false; const bool max_software_endstops = true; const int X_MAX_LENGTH = 205; const int Y_MAX_LENGTH = 205; const int Z_MAX_LENGTH = 57;
Re: X-axis optical endstop failure January 06, 2015 10:20PM |
Re: X-axis optical endstop failure January 07, 2015 10:25AM |
Re: X-axis optical endstop failure January 07, 2015 01:05PM |
Re: X-axis optical endstop failure January 07, 2015 02:09PM |
Re: X-axis optical endstop failure January 07, 2015 11:43PM |
Now you got me stumped. Have you tried using repetier to see if it works any better for you?Quote
Unbre
I didn't find any endstop settings in pronterface, but I tryed to put the pins in the "+" side and pronterface does not respond on X-Home's button pressing, so I think to have pronterface X setup as min.
Re: X-axis optical endstop failure January 08, 2015 06:03AM |
Re: X-axis optical endstop failure January 09, 2015 08:43AM |
Re: X-axis optical endstop failure January 09, 2015 09:42AM |
// The pullups are needed if you directly connect a mechanical endswitch between the signal and ground pins. const bool X_ENDSTOPS_INVERTING = false; // set to true to invert the logic of the endstops. const bool Y_ENDSTOPS_INVERTING = false; // set to true to invert the logic of the endstops. const bool Z_ENDSTOPS_INVERTING = false; // set to true to invert the logic of the endstops. //#define DISABLE_MAX_ENDSTOPSI'll be able to tell the correct settings later if you don't find until this evening.
Re: X-axis optical endstop failure January 12, 2015 07:02AM |
const bool ENDSTOPS_INVERTING = false;Setting it true x-min become H and keep always H so the axis move in only one direction, as aspected.
#define ENDSTOPPULLUPSAnd somthing changed in the good direction, when the endstop is trigged sometimes it return x-min: H and sometimes x-min:L.
