Filament extruder recomendations January 21, 2015 08:55PM |
Re: Filament extruder recomendations January 22, 2015 01:49AM |
Re: Filament extruder recomendations January 22, 2015 11:51AM |
tanner331
Hi
I have a Reprap Rostock 3d printer and I keep having issues with the extruder slipping on the filament, this then causes the filament to stop feeding. I am wondering if there is a different extruder I can use to prevent this problem. The extruder has to have a bowden tube mount because the design of the Rostock 3d printer only allows for a bowden mount. I currently use an AIRTRIPPER BOWDEN EXTRUDER V3 extruder, a Mk8 drive gear, and a E3D v6 hotend. I also bought a hobbed bolt so I can build a extruder that uses drive gear or a hobbed bolt.
Thanks
Tanner
Re: Filament extruder recomendations January 22, 2015 11:56AM |
Re: Filament extruder recomendations January 22, 2015 03:01PM |
tanner331
I use both ABS and PLA This problem occurs more with PLA but it also occurs with the ABS.
Re: Filament extruder recomendations January 22, 2015 03:52PM |
tjb1
tanner331
I'd say your main problem is the E3D, it's terrible with PLA and likely jamming and causing the extruder to strip the filament.
Re: Filament extruder recomendations January 22, 2015 04:08PM |
dougal1957
tjb1
tanner331
Sorry but I would have to disagree re the E3D being bad with PLA as long as it is an original one that is (The clones may be a different thing) I have had no issues with PLA with mine at all.
Re: Filament extruder recomendations January 23, 2015 04:09AM |
You mean that extruder with a piece of hose instead of inexpensive spings ? Well, if we're talking about the same extruder, I'm not surprized at all.Quote
tanner331
Re: Filament extruder recomendations January 23, 2015 07:37AM |
Zavashier
+1 for a good geared extruder like the white one posted above.
tanner331
Re: Filament extruder recomendations January 23, 2015 08:28AM |
Re: Filament extruder recomendations January 23, 2015 10:55AM |
Zavashier
I appreciate you're a happy user, I've finaly met 1 enthusiast user. Today I know better people with issues with that hose that cannot deliver constant pressure, especialy with heat issues. The specifications will be significantly different in Alaska or California, it's easy to understand if you try. Both changed for springs. Today you can find any linear spring you like through the web or any automotive spare parts seller. What's the benefit of a hose tightener for the user ? IMHO using plastic hoses are a fake good idea. Saves money for the manufacturer, brings possible problems to the user. I believe on Murphy's law. When something can go wrong, it will.
Re: Filament extruder recomendations January 23, 2015 01:41PM |
Re: Filament extruder recomendations January 25, 2015 07:28AM |
Re: Filament extruder recomendations February 02, 2015 06:24PM |
Re: Filament extruder recomendations February 02, 2015 07:33PM |
Re: Filament extruder recomendations February 02, 2015 09:35PM |
mk3a
I have a similar setup and maybe my experience will help.
I have a Rostock Mini with a bowden extruder and I am also using the airtripper design. I originally thought the filament was slipping, but it turned out the motor was kicking backwards because it couldn't generate enough torque to move the filament. I'm switching to a planetary gear design as it is more reliable, especially when printing at higher speeds that demand more torque from the extruder.
If it is actually slipping, one thing you can do to improve the hose's elasticity is to fill the hose with silicone caulk (after disassembling the extruder of course). Then poke a couple holes through it for the screws and let it sit around for a few days to cure fully (the inside tends to remain liquid long after the exterior has solidified, so poking holes in it should help). Afterward it can take a lot more pressure without crushing.
Re: Filament extruder recomendations February 03, 2015 06:06PM |
