New build what controller to use? January 30, 2015 10:34PM |
Re: New build what controller to use? January 30, 2015 11:04PM |
Re: New build what controller to use? January 30, 2015 11:22PM |
Re: New build what controller to use? January 30, 2015 11:45PM |
Re: New build what controller to use? January 31, 2015 03:50AM |
MindRealm
SmoothieBoard has the stepper drivers built into the board, so if one fails, you can't just plug in another one... I'll stick with RAMPS.
Re: New build what controller to use? January 31, 2015 06:44AM |
Re: New build what controller to use? January 31, 2015 09:55AM |
Re: New build what controller to use? January 31, 2015 02:44PM |
Re: New build what controller to use? January 31, 2015 03:03PM |
Embed
I think I'm going with the megatronics. I don't like using anything too new. Let others work out the bugs. Any thoughts on software? I'm on a windows machine, not Linux.
Re: New build what controller to use? January 31, 2015 04:08PM |
MindRealm
Zavashier
The Mega/Ramps configuration is getting older, that's true. But it stills works fine. Those new boars, smoothieboard, Rambo, etc. are better, but also much more expensive. Actualy, I don't know if the improvements justify the price.
Zavashier
Anyway to me the price is still a factor. Otherhand, there is a need of consistency. If the machine will use Hiwin linear rails, a smoothieboard will match the guides quality. If the machine will use chinese LM8UU and M5 threaded rods, a Mega/Ramps is pretty enough.
Zavashier
Last, remember the smoothieboard require its own firmware, there's still a few users, so you'll need to contact the developer for debuging/support if needed.
Re: New build what controller to use? January 31, 2015 05:46PM |
Re: New build what controller to use? January 31, 2015 05:57PM |
Zavashier
Second, the price. A reprap with a ramps that's a 250-500€ budget. Most repraps are within that range. A smoothieboard increases the budget of at last 40%.
Re: New build what controller to use? January 31, 2015 08:11PM |
Re: New build what controller to use? February 01, 2015 05:38AM |
Re: New build what controller to use? February 01, 2015 06:29AM |
Zavashier
Easy sayings Dentist. To most of people, budget matters. Expensive does not always mean good,
Zavashier
and inexpensive does not always mean cheap.
Zavashier
Today lines are blured. I aquired my Ramps in the kit, it's surely a cheap chinese version (under $8 I guess). It still works fine up to 600 printing hours now.
Zavashier
It already done its $8 job. I never had to debug or adjust anything on it after initial setup. No burn out to report, like most of the users. The "waisted" time (also "learning" time to me) with my kit was not because of controler issues, but extruder and mecanical parts only. Anyway, apreciate some people does not have $200 to invest into a controler board.
Zavashier
Most of the machines works under Mega/Ramps boards and works just fine. They won't print at high speed anyway because of their overall engineering. So, that "old" boards match the actual printers needs. Once again, with that boards, you can get excellent print quality with no headaches or endless tuning. I'm aware the smoothieboard do it better, but don't say that older gen cards don't work fine. You know it's not true.
Zavashier
Arthur, I saw some days ago a video of you at Ponant Factories, when you were talking about the next gen Smoothieboard, with new features to strike back a possible "Milkshakeboard". If I understood well what you said.
Zavashier
The smoothieboard looks to me like a swiss army knife.
Zavashier
You said the new features will make the board a bit more expensive.
Zavashier
Your company is based at a fablab's and your project follows an endless growth logical, like a commercial business.
Zavashier
To me, a project is done when you've nothing more to remove, not when you've got nothing more to add. Is there a workshop in the smoothieboard community working on a simplified version of the board ?
Zavashier
Like suppression of the features that are not used buy everybody ? I mean the RJ45 port for example,
Zavashier
not realy usefull on our wireless world.
[/quote]Quote
Zavashier
That could make an affordable version of the board, at the same time, it opens to the board a huge amount of users with simple needs, and low budget, whom are most of us...
Re: New build what controller to use? February 01, 2015 08:08AM |
Re: New build what controller to use? February 01, 2015 12:58PM |
Re: New build what controller to use? February 01, 2015 01:21PM |
Zavashier
Just the Ramps/Marlin users a ways more numerous. Aren't they ?
Re: New build what controller to use? February 01, 2015 01:24PM |
Zavashier
@Arthur, communication is problematic with you.
It's the seccond time I saw you investing a topic and trying to close the mouth of anybody who are not amazed by your board.
Zavashier
I wonder if you just want to promote your board or if your're basically bloated with pride ?
Zavashier
To treat right people who don't think like you, won't lower your succès or decrease the quality of your board. You could make friends instead of ennemies. Never mind.
Zavashier
I could do like you, extracting questionable pieces of your sentences and dislaiming step by step with claim and smugness.
Zavashier
There's just thoussands of happy Ramps users printing everyday pretty nice parts. Oh arthur, forgive them they know not what they do...
Re: New build what controller to use? February 01, 2015 01:38PM |
Re: New build what controller to use? February 01, 2015 01:42PM |
dougal1957
The things I like about the Smoothie is the way the Config's are done Firmware updates are the easiet of them all (No Arduino environment needed to compile your firmware first which is needed on both the Ramps and the RADDS solutions) the Duet is also easy in the way the config is done (Possibly even easier than the Smoothie as the file is smaller and I'm sure that Arthur won't mind me saying this)
Re: New build what controller to use? February 01, 2015 01:56PM |
arthurwolf
dougal1957
You said something bad about Smoothie I'm going to kill you !!!
More seriously, yes, we are aware of the issue, and we are working on removing some options from the default configuration files to make them more compact.
It'll also solve the issue of people modifying options that they don't understand and that are very rarely used ( the options will still exist but be documented in the wiki and be absent from the files by default ).
Re: New build what controller to use? February 01, 2015 07:43PM |
Re: New build what controller to use? February 02, 2015 12:58PM |
Re: New build what controller to use? February 02, 2015 02:01PM |
Fitz
I really hate to waiste my time and answer the original question, but :
I like the Megatronics solution because
1. it combines the Arduino and Ramps into 1 compact board
2. you can use the 1/32 drivers (though, at first I was confused about how many jumpers to use)
Re: New build what controller to use? February 02, 2015 02:29PM |
Re: New build what controller to use? February 02, 2015 02:34PM |
MindRealm
Not meaning to poke anyone in particular, but I have been in the electronics business for a fairly long time and while there are arguments for integrated solutions (having the MCU, drivers, regulators, MOSFETs, etc. on one board), these are problematic in case of a component failure (or damage by a novice).
Re: New build what controller to use? February 02, 2015 03:24PM |
arthurwolf
Nothing wrong with external drivers ... if they are done right.
