Prusa i3 printer stops heating after 100-110c
February 09, 2015 05:42AM
Hi fellow reprappers,
Yesterday i tried to print with abs for the first time.
When my bed is at about 100-110c (the max it seems to get) it stops heating the bed and extruder after a while.
If i disconnect and reconnect to repetier host i can heat up again and it goes fine for 20 mins and then it happens again.
I was thinking it was my power supply since the power supply fan turned on right after the "shutdown".
I used another power supply, with different cable to ramps, and the issue remains.
I dont know if this issue was always there or not since i printed pla before and had no need for such high temperatures.
Anyone with some advice?
Thanks
Re: Prusa i3 printer stops heating after 100-110c
February 09, 2015 09:08AM
What type of electronics are you using? (RAMPS, etc..)
-David
Find me online at:
Thingiverse
Instructables.com
LinkedIn
Facebook
Check out my FolgerTech Prusa i3 (plexi) at MindRealm.net
February 09, 2015 09:19AM
Sorry i should have posted that,
I am using ramps 1.4, 12 v power supply
Edited 1 time(s). Last edit at 02/09/2015 09:20AM by Govahnator.
February 09, 2015 09:36AM
A better question is what type of power supply is being used? It sounds like it may be functioning at the upper threshold of its output capacity, popping the breaker from running the heated bed at a 100% duty cycle to hold 110C.....
February 09, 2015 10:07AM
...or the polyfuses on the RAMPS board may be opening.
-David
Find me online at:
Thingiverse
Instructables.com
LinkedIn
Facebook
February 09, 2015 10:52AM
vreihen
That is what i was thinking. I have the 12 V / 360 W POWER SUPPLY aluminium case.Output:
Voltage: 12 VDC ± 5 %
Rated current: 30 A
Rated power: 360 W
Ripple & noice: 150 mV
Lad regulations: ± 1 %
The other power supply i tried is an ATX 600 W , same issue, but this one only reaches 104 max.
Edited 2 time(s). Last edit at 02/09/2015 10:54AM by Govahnator.
February 09, 2015 11:00AM
Is the power supply under the heated bed, where it might be overheating?????
February 09, 2015 11:05AM
vreihen
No it is not connected to the printer in any way
