What kind of updates have you made to your Folgertech Prusa I3? February 15, 2015 09:59PM |
Re: What kind of updates have you made to your Folgertech Prusa I3? February 17, 2015 08:29AM |
Re: What kind of updates have you made to your Folgertech Prusa I3? February 17, 2015 09:40AM |
Zavashier
Well I did a lot of necessary improvements :
- Rework Xends (for belt tensioning and endstops)
- Xcarriage redesigned to hold accessories (lights, fans, sensors...) and cable management
- Wade style extruder with E3D hotend (huge improvement !)
- Rework Y motor support
- Rework Y belt tensioning system
- Rework Y endsop support (and opical endstop)
- Redesigned Y bearing bushings
- New Y bed carriage (HQ 10mm particle board, still works fine)
I changed the extruder and X motors, and changed all the LM8UU bearings for Igus polymer bearings (a big step ehead for print quality improvement and it's so smooth and quiet !).
Actualy working on the enclosure : torsion box base on drawer slides for easy maintenance, inbox spool holder. I think about a touchscreen control thru Raspberry Pi and Octoprint + webcam.
Re: What kind of updates have you made to your Folgertech Prusa I3? February 17, 2015 04:57PM |
Re: What kind of updates have you made to your Folgertech Prusa I3? February 18, 2015 02:59PM |
Re: What kind of updates have you made to your Folgertech Prusa I3? February 18, 2015 03:35PM |
Re: What kind of updates have you made to your Folgertech Prusa I3? February 18, 2015 05:43PM |
MakerFront
I haven't made any alterations to mine.
I am getting beautiful prints at 50 micron with a stock setup (yes, that's 0.05 layer height)
My advice:
Spend the time you would spend re-working parts that you "think" will make it print better on calibration instead. The printer in itself will perform great if calibrated properly. You can print and re-design every part on the printer, but if you don't set aside the time necessary to calibrate it, it's all a moot point.
Everything else you do to it is just "bling" in my opinion.
The only thing I may agree with is the linear bearings, they're a bit rattly, but they do function well on mine with no noticeable print defects (even at 50 micron)
May I also mention, I am a third party to FolgerTech, not affiliated besides writing their manuals and some firmware. I have built, tested and calibrated about 50 3d printers in the past year (15 of them from FolgerTech)
Re: What kind of updates have you made to your Folgertech Prusa I3? February 18, 2015 06:30PM |
I want to be sure to get you right. Do you pretend the Folger's prusa I3 is the top of the top of 3D printers, or do you pretend people are so stupid they can't see if something's wrong with their printer ?Quote
MakerFront
My advice:
Re: What kind of updates have you made to your Folgertech Prusa I3? February 18, 2015 09:11PM |
Zavashier
Actualy I'm on holidays, far away from home. So I won't be able to share my own designs. Anyway, bearings can be found directly on the Igus website (URL depends of the area where you live, google it) under the reference Drylin RJM-01-08. EmotionTech's Prusa I3 Rework files are on thingiverse.
Re: What kind of updates have you made to your Folgertech Prusa I3? February 20, 2015 05:08PM |
Zavashier
MakerFront
My advice:
I bought the Folger's kit because there were people here, absolutely delighted by that kit, and I trusted them. As a newbie I wanted a kit : something simple to understand what FDM is all about. As a living, I'm engineer in mecanical studies. When I recieved the kit, I was a bit upset : 6mm acrylic frame became 5mm something, 8mm rods became 7.78mm, bended rods, bearings loosing balls, delaminating/braking parts, bad packaging, broken frame, and so on. The build was easy within 4 hours, but setting the machine square was a real problem. The structure is not stiff enough, and it twisted in all dimensions each time you try to set something. My kit definitely can't reach a precision of 50µ. In layer eight maybe, but as that chinese rods are not straight (I measured +-0.3mm) it's even impossible to get a .3mm flat layer. Try to measure acurately your parts, if you own machinist measuring tools. But the worst of all was the extruder. I waisted weeks on temperature calibration with non acceptable results to my eyes, and only on small parts, because long prints always ended by filament jams. That hotend is rubbish, even if I used the lowest possible temperature for my filament. Reasons ? A undersize heatsink with a lazy cheap fan, overheat difuses deeply in the mounting block and in the motor (which ended definitely jammed too). No tensioning at all on the extruder. To me, the Folger's kit is made out of the cheapest parts money can buy. Now I've seen a lot of prusa I3 working, from standard v1.0 to rework versions, and I can compare. Folger's is the worst I've ever seen.
Even if I was stupid to "think" improvements could make things better, each improvement I did cured problems instantly (a piece of chance maybe). Especialy the Extruder/hotend improvement : best results first fime any time, whatever the temperature I use, even very high ones. No more jams. That's what I call a good extruder. No need to waste time on epic calibrations. Using better motors makes fast prints possible too without loosing steps. And I could argue point by point with the same results. From bearings to motor mount, passing by Z wobble suppression.
Re: What kind of updates have you made to your Folgertech Prusa I3? February 20, 2015 05:12PM |
MakerFront
Zavashier
MakerFront
My advice:
I'm not going to get into an all-out mud slinging contest on here, being a business owner that sells, builds and services 3d printers, I thought I'd offer my professional opinion.
Maybe your parts came out of a bad batch somewhere along the line. That is inevitable with every company like this. At the quantities these guys have to buy to get the price that low, in-house QC is near impossible.
All I'm saying is that it is a functioning 3d printer kit for $319, it's not a Stratasys or 3DS machine (which we own one of each) and it's not intended to be one either. I wouldn't expect a machine like that for that price and I'm not pretending that it is. I am amazed at what this sub-$400 machine can do compared to our $180K Fortus. We use them in the office for less expensive prototyping before we print it out on the big boy.
Cheers!
Re: What kind of updates have you made to your Folgertech Prusa I3? February 20, 2015 05:47PM |
Re: What kind of updates have you made to your Folgertech Prusa I3? February 21, 2015 02:33AM |
Re: What kind of updates have you made to your Folgertech Prusa I3? February 24, 2015 01:26AM |
Re: What kind of updates have you made to your Folgertech Prusa I3? April 17, 2015 06:10PM |
Re: What kind of updates have you made to your Folgertech Prusa I3? April 17, 2015 07:24PM |
Re: What kind of updates have you made to your Folgertech Prusa I3? April 17, 2015 07:46PM |
Re: What kind of updates have you made to your Folgertech Prusa I3? April 17, 2015 08:35PM |
enzo1027
I too switched the rods with a fresh set from McMaster. I was reading somewhere today about switching to delrin-like lined bearings for the x and y carriages. The guy said it was much quieter and much smoother movement. Considering the ones we got with the kit were par for the course, I think I'll give the composite bearings a shot! The Kossel just keeps dropping in price! I am so torn, and really should just pull the trigger. You can't beat it for $345!
What's wrong with the LCD?
Re: What kind of updates have you made to your Folgertech Prusa I3? April 17, 2015 09:33PM |
Vanbot
enzo1027
It kind of sounds like the Folger kit is a placeholder. That is, you build it and then, while the Folger components hold it together for you, immediately start replacing all the parts bit by. Lol
I guess as long as it's good enough to print some replacement parts for itself you're ahead. But I hadn't heard that the rods might be an issue before. Is it common that they're not straight? How does one straighten them? Vice?
Re: What kind of updates have you made to your Folgertech Prusa I3? April 17, 2015 10:18PM |
Re: What kind of updates have you made to your Folgertech Prusa I3? April 17, 2015 10:36PM |
Ecky
ENZO:
LCD: I can't get a display from it using marlin. I got the display working using a sample file in the U8glib library. It isn't the most important thing at the moment so I am not too stressed about it. I am in Canada so my big project tomorrow is changing to summer wheels & tires on my truck and getting a piece of glass for the printer.
Straightening the rods: I made a setup something like in the video above. I would use a piece of aluminium between the crowbar and the rod to avoid marking the rod. Cardboard is what I used.
Have a great weekend.
Re: What kind of updates have you made to your Folgertech Prusa I3? April 18, 2015 01:20AM |
enzo1027
Vanbot
enzo1027
Lol, it sure seems as it was a placeholder! I mean don't get me wrong, I knew full well going into this what I'd get. I spent a ton of time being as precise as I could building this thing, measuring, setting up, etc. It printed absolutely perfect out of the box. I couldn't be happier with it! That being said, there sure is a lot to improve upon from a quality/reliability aspect; but that's what tinkering is all about!
I've seen a few people's comments regarding the rods. It's to be expected with inexpensively sourced parts though. Two of my shafts were out about +.006-.009. You can absolutely attempt to straighten them, but I'd recommend against a vice. Take a look at this guy's video, it'll give you an idea of how to construct a jig / do it. Straighten a bent rod The rods were about $20 each if I remember from McMaster. For $40, I couldn't go wrong.
Re: What kind of updates have you made to your Folgertech Prusa I3? April 18, 2015 05:55AM |
