Best hot-end for fast printing? February 16, 2015 07:30PM |
Re: Best hot-end for fast printing? February 16, 2015 08:01PM |
Re: Best hot-end for fast printing? February 17, 2015 03:05AM |
FalloutBe
Hello,
I want to buy a good hot-end for fast printing for 1.75mm filament and +-0.4mm nozzle.
Am I correct if I'm looking only for hot-ends which have a long heating length?
I also want to be able to print Nylon with this, so high temperatures are also a must!
I found the pico hot-end; it has a long heating area which should help for fast printing. However it seems to be quite expensive.
The E3D volcano hot-end also seems promising but it's nozzles only go as small as 0.6mm
Any ideas?
Re: Best hot-end for fast printing? February 17, 2015 04:18AM |
I was thinking of higher than 200mm/s (this on a 200 to 50 micron layer height and with a 0.4mm nozzle)Quote
dc42
What do you mean by "fast" - have you a speed in mind?
This one also seems nice, but I saw in some videos that the fan mount is sitting quite loosely around the metal cooling fins?Quote
dougal1957
Try the E3D V6 nozzles go from 0.25 up to 0.8 and with a thermocouple (As supplied by RepRapWporld) is capable of going very hot but 290 as std is easy as well.
The Volcano is a modification to the E3D V6 by the way
HTH Doug
Re: Best hot-end for fast printing? February 17, 2015 06:41AM |
FalloutBe
And the length of the heating area is nowhere near as long as for example the pico hot-end.
