Helo comunity!
I'm looking to create a custom PCB heat bed to use with an Azteeg X3 PRO controller. I can't figure out though wich trace width i sould be using.
Data i know:
- Azteeg X3 PRO heat bed mosfets can handle 15 A (talking only about one heat bed on one mosfet, now any other combination)
- PCB heating area 500*250mm
- 12V will be used
- Cooper thickness is 35 micrometers
- Operation temperature - the normal for printing, up to 100ÂșC i suppose
The problem i'm facing is: to calculate width, total length is needed. But the total length depends on the width.. :/
Does anyone here know what configuration i should be using? (trace width and clearance between them)
I would be much appreciated if anyone who understands about this kind of stuff could help me!
Tks o/
