want to ask how to wiring inductive proximity sensor to ramps 1.4 board?
Posted by wendychai80
Re: want to ask how to wiring inductive proximity sensor to ramps 1.4 board?
April 14, 2015 09:19AM
hummm that may be my mistake.
I pluged black and blue to Z endstop on ramps and the Brown to the 12V on ramps.
The correct would be ?:
Black - Z Signal
Brown - 12V +
Blue - 12V -
is that it?
April 14, 2015 09:32AM
Yupthumbs up,that how im wired my sensor to the rampssmiling smiley
April 14, 2015 09:57AM
I tryed what you said, but no succes here. By the way, I´m using the 12-35V Output from the ramps, not the Aux PIN (wich, I dont know why I dont have)
April 14, 2015 10:42AM
Do you use resistor like in the video?
this is how i wired mine from the sensor into the ramps
from the pictures below,
inside the red circle there got brown and blue near the 11A there where i connect my + and - sensor wire
and another red circle there small black circle inside, there is where i insert my signal wire from the sensor
[imgur.com]
April 14, 2015 10:50AM
Nope.
You connected to the 12-35 input, I connected to the 12-35 output, maybe this is another mistake of mine. But the sensor lights up anyway.
The black cable is in the same position.
I use the same sensor, and did the same resistor hooking. By the way, the only difference is that my resistors instead of 10k and 15k are 100k and 150k.
thanks.
April 14, 2015 11:00AM
yup i connect it there, and it works for me.
April 14, 2015 11:03AM
I wiil try it right now!! hope neve dies!smiling smiley
April 14, 2015 11:23AM
ok. and here what my marlin mechanical settings look like
//=============================Mechanical Settings===========================
// Uncomment the following line to enable CoreXY kinematics
// #define COREXY
// coarse Endstop Settings
#define ENDSTOPPULLUPS // Comment this out (using // at the start of the line) to disable the endstop pullup resistors
#ifndef ENDSTOPPULLUPS
// fine endstop settings: Individual pullups. will be ignored if ENDSTOPPULLUPS is defined
// #define ENDSTOPPULLUP_XMAX
// #define ENDSTOPPULLUP_YMAX
// #define ENDSTOPPULLUP_ZMAX
// #define ENDSTOPPULLUP_XMIN
// #define ENDSTOPPULLUP_YMIN
// #define ENDSTOPPULLUP_ZMIN
#endif
#ifdef ENDSTOPPULLUPS
#endif
// The pullups are needed if you directly connect a mechanical endswitch between the signal and ground pins.
const bool X_MIN_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
const bool Y_MIN_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
const bool Z_MIN_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
const bool X_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
const bool Y_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
const bool Z_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
//#define DISABLE_MAX_ENDSTOPS
//#define DISABLE_MIN_ENDSTOPS
// Disable max endstops for compatibility with endstop checking routine
#if defined(COREXY) && !defined(DISABLE_MAX_ENDSTOPS)
#endif
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define E_ENABLE_ON 0 // For all extruders
// Disables axis when it's not being used.
#define DISABLE_X false
#define DISABLE_Y false
#define DISABLE_Z false
#define DISABLE_E false // For all extruders
#define DISABLE_INACTIVE_EXTRUDER true //disable only inactive extruders and keep active extruder enabled
#define INVERT_X_DIR true // for Mendel set to false, for Orca set to true
#define INVERT_Y_DIR true // for Mendel set to true, for Orca set to false
#define INVERT_Z_DIR false // for Mendel set to false, for Orca set to true
#define INVERT_E0_DIR true // for direct drive extruder v9 set to true, for geared extruder set to false
#define INVERT_E1_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false
#define INVERT_E2_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false
// ENDSTOP SETTINGS:
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
#define min_software_endstops false // If true, axis won't move to coordinates less than HOME_POS.
#define max_software_endstops true // If true, axis won't move to coordinates greater than the defined lengths below.
// Travel limits after homing
#define X_MAX_POS 210
#define X_MIN_POS 0
#define Y_MAX_POS 210
#define Y_MIN_POS 0
#define Z_MAX_POS 180
#define Z_MIN_POS 0
#define X_MAX_LENGTH (X_MAX_POS - X_MIN_POS)
#define Y_MAX_LENGTH (Y_MAX_POS - Y_MIN_POS)
#define Z_MAX_LENGTH (Z_MAX_POS - Z_MIN_POS)
Edited 1 time(s). Last edit at 04/14/2015 11:24AM by wendychai80.
April 14, 2015 12:27PM
Thanks wendychai80, but nothing worked so far. confused smiley
April 14, 2015 01:19PM
Do red led on the sensor brightly open or just dim when you put it near metal object?
April 14, 2015 01:28PM
brighty confused smiley
April 14, 2015 01:43PM
Sorry, but i dont know what else the problem should be, maybe you got bad sensor? or there somewhere inside the firmware that should be change.
Maybe you should open new thread and hopefully someone more knowledge and experiance can figure out what your problem should be.
April 14, 2015 02:02PM
Wndychai80, thank you so much for your attention. If get it working I´ll post a feedback here. One way or another I will put this thing to work LOL, because I just can´t handle anymore the pain of calibrating Z endstop every day smiling smiley
April 14, 2015 02:07PM
LOL, i know the feelinggrinning smiley wish you luck to solve the problem
April 15, 2015 07:39AM
Working now, I have done the resistor thing wrong... my bad.
Now I´m facing some trouble with the marlin, everything I do results the same with the z offset. The nozzle is higher than I want
April 15, 2015 09:45AM
Glad to hear it working for youthumbs up
for me i do it like this
1: use a4 paper to position the nozzle properly
2: fix the sensor position
3: home all axis using G28 command
4: send G29 to probe bed
5: after it finish the G29 command then send this command G92Z10 this is to make the nozzle think it 10mm away from the bed
6: use A4 paper again and lower z axis 0.1 until you can feel the nozzle slightly touch the paper.
7: After that send M114 command to check all the axis position you will get something like this "X:0.00 Y:0.00 Z:0.00 E:250.00 Count X: 0.00 Y:0.00 Z:0.00"
8: Then just minus the current Z axis position with 10 (examples Z:9.80 so you should minus 9.80-10 = -0.2)
9: Inside your configuration.h find #define Z_PROBE_OFFSET_FROM_EXTRUDER 0.0 and change 0.0 to whatever result you get just now
10: then upload it to you controller
Hope this works for you.
April 18, 2015 01:03PM
I am having some problems hooking this up also. I have a NPN capacitive proximity sensor, hooked up with the 12V. If I just test it by itself, it seems to work fine. The red LED on the back lights up when it gets close to object, and the sensor wire (Black) goes from 9.5V to 0. The problem is in order to hook up to RAMPS I got a LM7805, and when i connect it to the sensor, the LED comes hard on, and I do not get any input as if was being triggered. Any ideas?
Thanks.
April 20, 2015 09:16AM
CptanPanic
Thanks.
So I did some more research, and it seems that I had things wrong. As this is a NPN sensor it seems I do not need the LM7805, as it acts as an open collector. So I should be able to just connect to endstop sensor pin with internal pullup, but this doesn't work either. When I do this, the LED on the sensor turns on as soon as I connect to pin.
April 20, 2015 09:21AM
Hello! Everything working here, the problem (aside the error I made with the wires) was the firmware. I was using one branch, and the branch has some bug that causes this problem. Solved now here with the stable firmware.
April 20, 2015 09:31AM
CptanPanic
CptanPanic
Thanks.
Sorry CptanPanic i didnt familiar with other sensor cause im just following other guide that i found and ask question here and there regarding my problem.
the sensor red led shine bright or just dim? or maybe you should double check your wiring again cause gustavogoulart sensor didnt work also until he fix the resistor wiring. Everything about wiring the sensor should be in this thread, and if this doesnt help you maybe you should open new thread about your problem cause i lack of knowledge about electronic thing.
April 20, 2015 09:34AM
gustavogoulart
Branch? is it in marlin firmware? lol i didnt know what that is. nevermind then, nice to hear everything work fine for you now smileys with beer
April 21, 2015 07:20AM
wendychai80
CptanPanic
CptanPanic
Thanks.
So it turns out it is actually working correct although the LED on the sensor is always lit.
April 24, 2015 09:04PM
Hi
Sorry to jump in on an open thread but can you please just confirm that with a 12 volt PNP type proximity you require two bridging resistors 10k and 15k por use the LM7805 diagram and if you use an 12 volt NPN type proximity you just require the pull down resistor to be enabled in the software?
Lastly capacitive sensors in my experience are very inaccurate and large. Why wouldn't you just take off the glass and install an aluminium plate with an inductive sensor?
Hi there!
I bought the regulator, but I´m afraid I can fry everything because I have no practice in eletronics, can someone show a diagram on how to wire things like this quote?
thanks,
ggherbaz
I usually set my sensors this way:
Brown and blue goes to power supply, this way I know my sensor have enough power to give me maximum sensing distance. Then I connect the black signal wire to an LM7805 pin 1, pin 2 goes to ground and pin 3 (regulated 5 volts) goes to signal pin on endstop connector.
There is a risk that if the regulator fails, the whole 12 volts will go to the board frying it, but it is minimal since usually when the regulator fails they stop supplying voltage and also the power consumption it so small that the regulator never get stressed enough to make it fail.
July 06, 2015 06:45AM
hai, im still using the resistor setting so i can't help you. maybe if you open new thread there someone will reply and help you there
July 10, 2015 09:33PM
jad51
I can confirm that the pnp will work with the resistor set up. the 10k resistor acts as a pull down also. Made up one but didn't connect to signal on board. It has no voltage when it is not near metal meaning no but voltage goes to 12 volts ( no load on 15k) when near metal (nc). Wise to use the 5 volt regulator. Firmware needs to be change in the logic settings.
September 02, 2015 02:03PM
Hi! I'm currently following this thread and I am very excited to try this out on my Graber i3...So after reading all the posts in this thread, I want to ask if this setup on attached image is the one correct to use the PNP proximity sensor with a LM7805 regulator. Do I need connect the LM7805 pin 2 (ground) as in the image or in same ground connection of PNP sensor?
Thank you all for all informations so far!
open | download - RAMPS_PNPProximitySensor.jpg (247.3 KB)
September 11, 2015 11:17PM
I have a M12 NPN 3 wire NO proximity sensor.
Wiring it the way Smerrett79 did on his Smartrap Core..
Brown - 12v
Black - Ground
Blue - Signal
I get a Dimly lit LED and 2.84v without metal near sensor, and a Brightly lit LED and 0v with metal near sensor.
I connected the blue directly to RAMPS Zmin Signal as he said to, and it worked.
I made sure ZMin Endstop Inverting was set as true like below.
Borrowed the Image above and edited it to match for NPN sensors.
Edited 1 time(s). Last edit at 09/11/2015 11:18PM by madmike8.
September 12, 2015 12:16PM
madmike8
Brown - 12v
Black - Ground
Blue - Signal
[attachment 62002 RAMPS_NPNProximitySensor.png]
Yes! I used a NPN sensor as well. Worked out pretty well but I had to use a voltage divider. The only problem now is that my layers seems to be "sliced" by the nozzle...the first layers are good but I notice that the top of them (all other layers) had been marked by the nozzle, almost as if the Z axis are not going up as high as it supposed to be...maybe it's the weight added by the sensor? I don't know... :/
EDIT 1: I figured out that the problem is on X and Y axis.... these attached 3d printed parts supposed to be 20mmx20mmx3mm (XxYxZ) but I got 16.7mmx16.7mmx3mm I think I need to tweak the firmware again because I dont think this is related to the belts...
EDIT 2: It was the DEFAULT_AXIS_STEPS_PER_UNIT hehehe smiling smiley
Edited 3 time(s). Last edit at 09/12/2015 03:16PM by mccarmo.
open | download - 20150912_005.jpg (537.7 KB)
