Aluminium Heat Bed March 01, 2015 05:04PM |
Re: Aluminium Heat Bed March 01, 2015 06:01PM |
Re: Aluminium Heat Bed March 01, 2015 10:15PM |
Re: Aluminium Heat Bed March 02, 2015 08:07AM |
Re: Aluminium Heat Bed March 02, 2015 12:24PM |
Re: Aluminium Heat Bed March 02, 2015 12:47PM |
ggherbaz
If your power supply can handle it and your board is well ventilated, check the power setting in your firmware and raised up to full 255.
Re: Aluminium Heat Bed March 02, 2015 10:15PM |
Re: Aluminium Heat Bed March 02, 2015 10:33PM |
Re: Aluminium Heat Bed March 02, 2015 10:35PM |
Re: Aluminium Heat Bed March 03, 2015 12:34AM |
Re: Aluminium Heat Bed March 03, 2015 06:15AM |
Re: Aluminium Heat Bed March 03, 2015 06:38AM |
dave3d
Thanks for all your replies. I will try and answer all the points raised. I have also done some further electrical tests.
The power supply is a standard Reprap 12v 30A switching power supply that came with the printer kit, an OrdBot. To my knowledge the voltage is not adjustable, at least not from the outside. It maybe if I take it apart. I measured the no load voltage at the bed and it is 12.5v. I do not wish to increase it. I have a history of damaging Arduino boards!
My new heat bed is a Reprap Mk3
[www.ebay.co.uk]
I am controlling the bed via a solid state 40A relay. It is just on/off control. I am not using PID. I have used it for a long time satisfactorily with my other heat bed. The only thing that has changed is the aluminium bed. I have my printer in my living room, typically 20 deg C. There are no strong draughts. I have a small fan on the extruder but it was turned off for these tests. I have fitted the heat bed upside down with thermal insulation underneath. The printer bed mounting plate underneath that does not get hot. However as mentioned the levelling springs get too hot to touch. They are in contact with the aluminium bed. I need to try fitting small fibre washers both sides.
I measured the resistance of the bed (cold) at 1.3 ohms. I fitted an ammeter in series with the bed and got the following results
Time Amps Temp deg C
start 8.37A 20C
1min 7.75A -
2min 7.5A -
3min 7.25A 65C
4min 7.13A 72C
5min 7.08A 75C
6min 6.94A 81C
7min 6.87A 84C
8min 6.82A 88C
10min 6.73A 93C
18min 6.62A 100C
sorry can't do tables
Because it was taking so long to heat up, the heater cut out at just over 100 deg C with the error message "HEATER DECOUPLED". This is a safety feature in the Repetier firmware. I could have reset it and carried on. The above results were without a glass plate or any cover over the aluminium heat bed. As can be seen, the current drops off as the bed heats up, presumably as the resistance alters with temp. I checked the voltage under load when it was at 70 deg C and got 11.31v.
I also checked the bed temp with an IR gun, which gave a reading 5 to 6 deg C lower, I think because of the reflectivity of the shiny aluminium surface.
I was thinking of getting a 24v power supply unit to power just the bed. Not sure what size but twice the voltage would be twice the amps I think. I will also try insulating the springs, there is heat loss there and I will re check my wiring and solder connections.
Re: Aluminium Heat Bed March 03, 2015 07:01AM |
Re: Aluminium Heat Bed March 03, 2015 07:36AM |
dave3d
dougal1957: under load from cold I I got 11.19v at the bed. At the SSR I measured 11.93v on supply side output terminal and 11.49v on the load (bed) side. Maybe I need to beef up the bed wiring.
Re: Aluminium Heat Bed March 03, 2015 07:56AM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Aluminium Heat Bed March 03, 2015 09:27AM |
Re: Aluminium Heat Bed March 03, 2015 10:22AM |
Re: Aluminium Heat Bed March 03, 2015 08:31PM |
dave3d
It seems other people have had the same problem: [forums.reprap.org]
There also appears to be different types of Mk3 heat bed. This is the one I have: [www.ebay.co.uk]
and there is a Wiki which shows a slightly different one: [reprap.org]
On mine, both earth wires are joined for 12v. The one on the Wiki has the +12v joined together. Because the circuit is bonded or printed onto a solid aluminium base the temp should be even across the bed I think. Aluminium is a very good heat conductor.
I am now thinking about switching to 24v for the bed. The Wiki says it will heat up to 100 deg C in 2 mins! which would be great. Combined with a 12v step down voltage controller for the Arduino/Ramps boards maybe. Anyone tried this?
Re: Aluminium Heat Bed March 03, 2015 11:10PM |
Re: Aluminium Heat Bed March 03, 2015 11:50PM |
Re: Aluminium Heat Bed March 04, 2015 03:53AM |
Re: Aluminium Heat Bed March 04, 2015 08:08AM |
Re: Aluminium Heat Bed March 04, 2015 09:04AM |
Re: Aluminium Heat Bed March 04, 2015 01:33PM |
Re: Aluminium Heat Bed March 04, 2015 02:04PM |
the_digital_dentist
PID control is a very good and useful thing to have and use.
Re: Aluminium Heat Bed March 04, 2015 02:27PM |
Re: Aluminium Heat Bed March 04, 2015 05:05PM |
Nophead wrote:
If you put 24V on the 24V connections it wont get any hotter than 12V on the 12V connections (other than reducing the connection and MOSFET losses). It might heat more evenly though. You would need 30V to get the same heat as 15V on 12V connections.
the digital dentist wrote:
Running a 12V heater from a 24V supply will dissipate 4X the power at 100% duty cycle
dc42 wrote:
PID control of the bed is only of benefit if the bed heater is powerful enough that significant temperature overshoot occurs. With the typical Mk2 or Mk3 heated bed used in diy 3D printers, this is not the case unless they are operated with a higher than normal voltage. But some other heated beds do have significant overshoot, and benefit from PID.
Re: Aluminium Heat Bed March 04, 2015 05:44PM |
The heat generated is directly proportional to the current. Twice the voltage equals twice the current equals twice the heat generated.
Re: Aluminium Heat Bed March 04, 2015 08:51PM |
Re: Aluminium Heat Bed March 05, 2015 03:30AM |
the_digital_dentist
Your scope photo is impressive, but the avalanche is over in under 250ns and the ringing voltage has dropped below 20Vpk in under 1 us. The FETs in the RAMPS board are rated for 50A continuous and the SOA curve shows that they can handle >100A for 100 us (that's 400x the duration of the avalanche in your scope image).
the_digital_dentist
Marlin PID operates at a maximum of about 7Hz, plenty of time for the die to cool between those brief, in-spec avalanche events. SmoothieWare PID operates at a much higher frequency by default, so it is slightly more possible for it to cause a problem for the FET, but you can easily turn down the frequency with a config.txt variable if you're worried about it or if your FET heats up and you don't want to put a heat sink on it.
the_digital_dentist
I have never heard of anyone complaining about EMI from a 3D printer. I'm not saying it doesn't exist, I just haven't heard of anyone complaining about it. If I were trying to make a product to sell to consumers and had to pass UL, CSA, FCC, and/or TUV certification I might be concerned. If the EMI interfered with my wife's ability to watch Gilligan's Island reruns because it interferes with the TV or wifi signal I would be concerned about it. If EMI affected print quality I would definitely be concerned about it. But I'm not making a commercial product and it doesn't do either of those other things, so I am not concerned about it. I doubt anyone else is either.
the_digital_dentist
My print bed temperature varies by about +/- 1C with PID control and swings about +/-10C with bang-bang as reported by both Marlin and SmoothieWare which are certainly not laboratory grade instrument readings, but they're close enough to tell me what I need to know.
