Re: Aluminium Heat Bed March 05, 2015 12:37PM |
Re: Aluminium Heat Bed March 05, 2015 12:49PM |
Re: Aluminium Heat Bed March 05, 2015 01:01PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Aluminium Heat Bed March 07, 2015 06:31AM |
Re: Aluminium Heat Bed March 07, 2015 07:10AM |
Re: Aluminium Heat Bed March 07, 2015 11:13AM |
Re: Aluminium Heat Bed March 07, 2015 04:38PM |
Re: Aluminium Heat Bed March 16, 2015 08:12AM |
Re: Aluminium Heat Bed March 17, 2015 09:08AM |
Re: Aluminium Heat Bed March 28, 2015 02:16PM |
Re: Aluminium Heat Bed March 28, 2015 09:01PM |
Re: Aluminium Heat Bed March 28, 2015 09:20PM |
dave3d
A final follow up. I have now fitted the second 24v power supply unit to power just the bed. It is rated at 17 amps.
I still use on/off control via a SSR. I adjusted the output voltage of the 24v PSU so it gives around 15 amps, just to allow a margin.
It now heats up to 110 deg C in about 3 mins!
Re: Aluminium Heat Bed March 29, 2015 01:58PM |
Re: Aluminium Heat Bed March 30, 2015 09:07AM |
Re: Aluminium Heat Bed March 30, 2015 10:54AM |
alan richard
For on/off (bang bang) control, which is just like a regular thermostat, a mechanical (high current) relay is better, an SSR is a pointless expense that just drops voltage passing through it, if dc42 is to be believed and I think he probably is.
Re: Aluminium Heat Bed June 14, 2015 02:11PM |
Re: Aluminium Heat Bed June 15, 2015 03:54PM |
Re: Aluminium Heat Bed June 16, 2015 04:05AM |
mmutch
i have the same issue where my Mk3 bed wont go above 70c the thought i have is what about buying a second 24V supply and a relay (12v/24v) then running the 12v bed power cable from the ramps to a relay thats 12v on the coil then run the 24v power supply thro the switching side direct to the bed wired in 24v configuration that way whenever the ramps tells the bed to warm the relay will aloow for 24v direct to the bed with no other load however unless you got a solid state one you would get the click each time it turned on and off
anyone else see an issue with this?
Re: Aluminium Heat Bed June 16, 2015 10:12AM |
Re: Aluminium Heat Bed June 16, 2015 10:43AM |
Re: Aluminium Heat Bed June 16, 2015 12:25PM |
Re: Aluminium Heat Bed June 16, 2015 12:42PM |
AquaticsLive
Make sure the Solid state relay is a DC/DC one and a name brand one. The cheap ones on Amazon and ebay tend to be DC/AC with a new label. You can tell they are fake when they get hot, allot of them will be sold with a big heat sink. I have a Crydom D06D60 LINK just gets slightly warm with a my 360 Watt silicone heater. I tried the cheap FOTEK SSR ESSR-DD100A and it got super hot even with a heat sink and failed after a week in the closed position so be careful.
Re: Aluminium Heat Bed June 16, 2015 01:51PM |
Re: Aluminium Heat Bed January 18, 2022 09:05PM |
