Maker Slide Runout March 04, 2015 02:44PM |
Re: Maker Slide Runout March 04, 2015 03:51PM |
Re: Maker Slide Runout March 04, 2015 04:54PM |
Re: Maker Slide Runout March 04, 2015 05:20PM |
Re: Maker Slide Runout March 04, 2015 05:52PM |
Zavashier
691175002 you're rightn that 20 module extrusions can bend under load, even if it won't conform as easily as you think. Hopefuly we don't load them with a pound or two V-wheel guides are much better than you thing through. You should give them a try someday. Derlin wheels are strong, low friction and more durable than rubbish LM/SBR series bearings. In some configuration they allow more load in every direction than tiny MGN rails that bends even faster.
Re: Maker Slide Runout March 04, 2015 06:58PM |
Re: Maker Slide Runout March 04, 2015 07:29PM |
Re: Maker Slide Runout March 05, 2015 08:15AM |
Well, you totaly dislike that technology. You can make other choices for your machines if you like. All depends of the admissible load of a system. I use V-groove guides for a while, and it's an inexpensive, acurate and durable system. I used them to carry some aeronautic parts over 10.000 pounds on curved rails. Not with Makerslide rails and wheels of course, with Hepco adapted ones. I don't ask myself questions. I calculate which system fits better for the load. Then I'm confident. The derlin wheels are precise enough and can hold much load than the profile will stand before bending too much. A gantry made of a signle 20x40x400mm profile with plates, hotends, fans, thansmission and wiring will be far to weigh a pound. So the profile will be stiff enough. The plates are 5mm aluminium, they will not bend or twist as easily as common printed plastic parts. For most of 3D printing applications Makerslide/Openbuilds systems will be just fine. Don't trust me, calculate by yourself.Quote
691175002
I guess my point is that if you are concerned about the accuracy of an extrusion based design your first question should be "will it bend?", not "is it straight?". I'm very confident that deflection will be a much larger contributor to overall error than any bend or twist in the extrusion. Even more so if you add deflection from the v-wheels and their mounting plate and throw some acceleration into the mix.
