This is what I get when I try to compile it with the verbose error reporting on
Arduino: 1.0.6 (Mac OS X), Board: "Arduino Mega 2560 or Mega ADK"
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega2560 -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=106 -I/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino -I/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/variants/mega -I/Applications/Arduino.app/Contents/Resources/Java/libraries/LiquidCrystal -I/Applications/Arduino.app/Contents/Resources/Java/libraries/SPI /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/Marlin_RAMPS_EPCOS_i38.cpp -o /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/Marlin_RAMPS_EPCOS_i38.cpp.o
In file included from thermistortables.h:4,
from Configuration.h:371,
from Marlin_RAMPS_EPCOS_i38.ino:33:
Marlin.h:61: warning: only initialized variables can be placed into program memory area
Marlin.h:62: warning: only initialized variables can be placed into program memory area
In file included from Configuration.h:371,
thermistortables.h:213: warning: only initialized variables can be placed into program memory area
Using previously compiled: /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/LiquidCrystal/LiquidCrystal.cpp.o
Using previously compiled: /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/SPI/SPI.cpp.o
Using previously compiled: /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/malloc.c.o
Using previously compiled: /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/realloc.c.o
Using previously compiled: /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/WInterrupts.c.o
Using previously compiled: /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/wiring.c.o
Using previously compiled: /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/wiring_analog.c.o
Using previously compiled: /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/wiring_digital.c.o
Using previously compiled: /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/wiring_pulse.c.o
Using previously compiled: /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/wiring_shift.c.o
Using previously compiled: /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/CDC.cpp.o
Using previously compiled: /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/HardwareSerial.cpp.o
Using previously compiled: /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/HID.cpp.o
Using previously compiled: /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/IPAddress.cpp.o
Using previously compiled: /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/main.cpp.o
Using previously compiled: /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/new.cpp.o
Using previously compiled: /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/Print.cpp.o
Using previously compiled: /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/Stream.cpp.o
Using previously compiled: /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/Tone.cpp.o
Using previously compiled: /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/USBCore.cpp.o
Using previously compiled: /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/WMath.cpp.o
Using previously compiled: /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/WString.cpp.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/core.a /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/malloc.c.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/core.a /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/realloc.c.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/core.a /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/WInterrupts.c.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/core.a /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/wiring.c.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/core.a /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/wiring_analog.c.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/core.a /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/wiring_digital.c.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/core.a /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/wiring_pulse.c.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/core.a /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/wiring_shift.c.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/core.a /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/CDC.cpp.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/core.a /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/HardwareSerial.cpp.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/core.a /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/HID.cpp.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/core.a /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/IPAddress.cpp.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/core.a /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/main.cpp.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/core.a /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/new.cpp.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/core.a /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/Print.cpp.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/core.a /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/Stream.cpp.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/core.a /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/Tone.cpp.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/core.a /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/USBCore.cpp.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/core.a /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/WMath.cpp.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/core.a /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/WString.cpp.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-gcc -Os -Wl,--gc-sections,--relax -mmcu=atmega2560 -o /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/Marlin_RAMPS_EPCOS_i38.cpp.elf /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/Marlin_RAMPS_EPCOS_i38.cpp.o /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/LiquidCrystal/LiquidCrystal.cpp.o /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/SPI/SPI.cpp.o /var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp/core.a -L/var/folders/g3/0hxv0qgj5m74vjbv074fq2kr0000gn/T/build7838027751905878242.tmp -lm
core.a(main.cpp.o): In function `main':
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/main.cpp:34: undefined reference to `setup'
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/main.cpp:44: undefined reference to `loop'
