Y-Axis Issues (resolved) March 14, 2015 05:02AM |
Re: Y-Axis Issues March 15, 2015 01:06AM |
Re: Y-Axis Issues (resolved) March 15, 2015 08:49AM |
Re: Y-Axis Issues (resolved) March 15, 2015 09:18AM |
BenBB
It seems that the issue is the G codes that set the home positions, after setting them, the axis will NOT pass by that point, if you set the middle of the table to be X0,Y0 then the table will not pass that point if you say G1 Y-50 S1... for example.
G1 Y-200 S1 the S setting does not work, it does not wan to move the y Axis...
However I found a way round it, I simply manually move the table to the correct pos and then click home all, somewhere I read that there are bugs in the homing code...some Mxxx not working, it gives offset error.
Tx Ben
