Printer set up
Posted by rich1812
Printer set up
April 08, 2015 01:53PM
Hi, ever since I built the printer, I have it set up like this (pic.)
It has been working great. The other day, a friend come over, he told me that it is not good to have the extruder motor to drag the filament, Is it true?
Edited 1 time(s). Last edit at 04/08/2015 02:00PM by rich1812.
open | download - 3d.jpg (107.6 KB)
Re: Printer set up
April 08, 2015 04:21PM
Still newish myself, but you should be fine. The extruder motor is supposed to pull the filament off of the spool in order to push it through the hotend. As long as the spool unwinds easily and you haven't had any issues, I don't see the problem.
Re: Printer set up
April 08, 2015 06:25PM
Dead wrong. There is no better way to bring the filament to the extruder. It is almost a straight line path wherever the extruder is on the X axis and the only friction being where the spool turns on the pipe. You are doing fine. Don't change it.
Re: Printer set up
April 08, 2015 07:36PM
Thank you all for affirming my thought. The way I set it up, the spooler canr spin freely with very little resistance and the spooler can move left and right some what as the X axis pulls it.
