Folger Tech -- Limited to 100 mm for Z axis?? **SOLVED**
Posted by 55rebel
April 17, 2015 01:17PM
Build:
Folger Tech Prusa i3
RAMPS 1.4
Arduino Mega
Running:
Repetier Host V1.0.6
Arduino V1.6.3 --> Marlin_RAMPS_EPCOS_i38
When trying to slice an object with a height of 120 mm, I get a warning that "At least one object is outside the printable area...."
And sure enough, I can't get my extruder to venture above 100 mm.confused smiley
Question:
Why am I only allowed a 100 mm build height when printing?
According to Folger Tech specs, I should be able to print to at least 177 mm.
Can't find anywhere, where it limits me to 100 mm; not in Repetier Host or the configuration file/header.
Can anyone shed some light on this dilemma for me? Thanks!
//=============================Mechanical Settings===========================
// Uncomment the following line to enable CoreXY kinematics
// #define COREXY
// corse Endstop Settings
#define ENDSTOPPULLUPS // Comment this out (using // at the start of the line) to disable the endstop pullup resistors
#ifndef ENDSTOPPULLUPS
  // fine Enstop settings: Individual Pullups. will be ignord if ENDSTOPPULLUPS is defined
  #define ENDSTOPPULLUP_XMAX
  #define ENDSTOPPULLUP_YMAX
  #define ENDSTOPPULLUP_ZMAX
  #define ENDSTOPPULLUP_XMIN
  #define ENDSTOPPULLUP_YMIN
  //#define ENDSTOPPULLUP_ZMIN
#endif
#ifdef ENDSTOPPULLUPS
//  #define ENDSTOPPULLUP_XMAX
//  #define ENDSTOPPULLUP_YMAX
//  #define ENDSTOPPULLUP_ZMAX
#endif
// The pullups are needed if you directly connect a mechanical endswitch between the signal and ground pins.
const bool X_ENDSTOPS_INVERTING = true; // set to true to invert the logic of the endstops.
const bool Y_ENDSTOPS_INVERTING = true; // set to true to invert the logic of the endstops.
const bool Z_ENDSTOPS_INVERTING = true; // set to true to invert the logic of the endstops.
//#define DISABLE_MAX_ENDSTOPS
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define E_ENABLE_ON 0 // For all extruders
// Disables axis when it's not being used.
#define DISABLE_X false
#define DISABLE_Y false
#define DISABLE_Z false
#define DISABLE_E false // For all extruders
#define INVERT_X_DIR true    // for Mendel set to false, for Orca set to true
#define INVERT_Y_DIR false    // for Mendel set to true, for Orca set to false
#define INVERT_Z_DIR true     // for Mendel set to false, for Orca set to true
#define INVERT_E0_DIR false   // for direct drive extruder v9 set to true, for geared extruder set to false
#define INVERT_E1_DIR false    // for direct drive extruder v9 set to true, for geared extruder set to false
#define INVERT_E2_DIR false   // for direct drive extruder v9 set to true, for geared extruder set to false
// ENDSTOP SETTINGS:
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
#define min_software_endstops false //If true, axis won't move to coordinates less than HOME_POS.
#define max_software_endstops true  //If true, axis won't move to coordinates greater than the defined lengths below.
// Travel limits after homing
#define X_MAX_POS 200
#define X_MIN_POS 0
#define Y_MAX_POS 200
#define Y_MIN_POS 0
#define Z_MAX_POS 185
#define Z_MIN_POS 0
#define X_MAX_LENGTH (X_MAX_POS - X_MIN_POS)
#define Y_MAX_LENGTH (Y_MAX_POS - Y_MIN_POS)
#define Z_MAX_LENGTH (Z_MAX_POS - Z_MIN_POS)
// The position of the homing switches
//#define MANUAL_HOME_POSITIONS  // If defined, MANUAL_*_HOME_POS below will be used
//#define BED_CENTER_AT_0_0  // If defined, the center of the bed is at (X=0, Y=0)
//Manual homing switch locations:
#define MANUAL_X_HOME_POS 0
#define MANUAL_Y_HOME_POS 0
#define MANUAL_Z_HOME_POS 0
//// MOVEMENT SETTINGS
#define NUM_AXIS 4 // The axis order in all axis related arrays is X, Y, Z, E
#define HOMING_FEEDRATE {50*60, 50*60, 50, 0}  // set the homing speeds (mm/min)
// default settings
// Origanal Settings---> #define DEFAULT_AXIS_STEPS_PER_UNIT   {80,80,4000,90}  // default steps per unit for ultimaker {78.7402,78.7402,200*8/3,760*1.1}920
#define DEFAULT_AXIS_STEPS_PER_UNIT   {81.71,81.73,4000,90}  // default steps per unit for ultimaker {78.7402,78.7402,200*8/3,760*1.1}920
#define DEFAULT_MAX_FEEDRATE          {250, 250, 2, 22}    // (mm/sec)
#define DEFAULT_MAX_ACCELERATION      {1000,1000,5,1000}    // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for skeinforge 40+, for older versions raise them a lot.
#define DEFAULT_ACCELERATION          500    // X, Y, Z and E max acceleration in mm/s^2 for printing moves
#define DEFAULT_RETRACT_ACCELERATION  500   // X, Y, Z and E max acceleration in mm/s^2 for r retracts
// Offset of the extruders (uncomment if using more than one and relying on firmware to position when changing).
// The offset has to be X=0, Y=0 for the extruder 0 hotend (default extruder).
// For the other hotends it is their distance from the extruder 0 hotend.
// #define EXTRUDER_OFFSET_X {0.0, 20.00} // (in mm) for each extruder, offset of the hotend on the X axis
// #define EXTRUDER_OFFSET_Y {0.0, 5.00}  // (in mm) for each extruder, offset of the hotend on the Y axis
// The speed change that does not require acceleration (i.e. the software might assume it can be done instanteneously)
#define DEFAULT_XYJERK                20.0    // (mm/sec)
#define DEFAULT_ZJERK                 0.4     // (mm/sec)
#define DEFAULT_EJERK                 5.0    // (mm/sec)
Edited 1 time(s). Last edit at 04/17/2015 02:24PM by 55rebel.
Re: Folger Tech -- Limited to 100 mm for Z axis??
April 17, 2015 01:27PM
Your firmware is set for 185, so the problem is in the slicer. I don't use slic3r or Repetier, but somewhere in the main settings should be the built plate size.
April 17, 2015 01:49PM
Thanks for the quick responce ggherbaz.
In main settings, the only options provided for are for the X and Y axis ....that I can tell; both presently set at 200 each
What is it that you use?
Edited 1 time(s). Last edit at 04/17/2015 01:50PM by 55rebel.
April 17, 2015 02:23PM
**SOLVED**
I was looking in the wrong place... "Configuration" under Slicer Tab --> printer settings.
Instead, it's in "printer settings" (gear symbols) at the top right in Repetier Host...............my bad tongue sticking out smiley
April 17, 2015 02:29PM
My guess is your using Repetier-Host... in the 'Printer Settings' dialog on the 'Printer Shape' tab you need to change the 'Print Area Height' (default is 100mm).
Hope this helps!
PS/FYI.. Slic3r doesn't have a max z setting. Cura has a max z height in the 'Machine Settings'.
April 17, 2015 02:30PM
Doh! Sidetracked before i pushed 'post' and you beat me to it smiling smiley
April 17, 2015 02:32PM
A BIG THANKS, anyway! spinning smiley sticking its tongue out
Re: Folger Tech -- Limited to 100 mm for Z axis?? **SOLVED**
April 17, 2015 03:57PM
Glad you find it.
I use Simplify3d.
April 17, 2015 04:53PM
Thanks ggherbaz, I'll have to check that out. "Simplify" is the "Key" word there, for me anyway.... smiling smiley
