Hi
I am upgrading my rostock 3d printer to a smoothieboard and upgrading to a e3d chimera dual extruder. I started with a E3D V6 and ramps 1.4.
I am wondering what current rating of power supply I should get? I have 2 16amp power supplies that currently power my ramps board,but I noticed that there is only one 12V input so I need to get a larger power supply.
The one 16 amp power supply has a 5V out so I can use it for the 5V in on the Smoothieboard.
I have seen power supplies that use a Watt rating instead of an amp rating so what would be the approximate size in both ratings? Is the conversion just P = V*A?
I will probably upgrade to a LCD screen so I will need a power supply big enough for it as well.
Thanks
Tanner
