Bed Heater Maxing Out and Unable to Maintain Temp April 21, 2015 10:14AM |
Re: Bed Heater Maxing Out and Unable to Maintain Temp April 21, 2015 11:31AM |
Re: Bed Heater Maxing Out and Unable to Maintain Temp April 21, 2015 03:29PM |
Re: Bed Heater Maxing Out and Unable to Maintain Temp April 22, 2015 10:19PM |
Re: Bed Heater Maxing Out and Unable to Maintain Temp April 23, 2015 03:18AM |
Re: Bed Heater Maxing Out and Unable to Maintain Temp April 24, 2015 12:10AM |
Re: Bed Heater Maxing Out and Unable to Maintain Temp April 24, 2015 02:01AM |
Re: Bed Heater Maxing Out and Unable to Maintain Temp April 26, 2015 01:30PM |
Re: Bed Heater Maxing Out and Unable to Maintain Temp April 26, 2015 02:06PM |
atheimer
After digging into the FET's as recommended, I came to the conclusion that I need to replace the mainboard (I have a knock-off Sanguinololu clone that came with my original kit so replacing the FET is not an option). The other alternative is to just relay the heated bed power directly from my PS.
So that's what I'm going to try first, connecting a solid-state-relay up... and seeing if that solves my problem for the short-term. I suspect I'll be replacing the power supply next but it can't hurt to see if the juice is there. (230w 20a supply)
I probably would've gone the new mainboard route but it appears Smoothie's and the other popular 32bit boards are sold-out so I'll try and hack it together for a while longer.
I am amazed though, all of the problems and the subsequent fixes have really improved my machine.... Print times are down, accuracy is up, and hopefully the heated bed will be speedier with this addition of bed insultation, 12ga wire, and relayed power.
Thanks for all the help (happy to hear continued opinions on this issue as well)
Cheers!
Re: Bed Heater Maxing Out and Unable to Maintain Temp May 10, 2015 09:14AM |
Re: Bed Heater Maxing Out and Unable to Maintain Temp May 10, 2015 09:37AM |
Re: Bed Heater Maxing Out and Unable to Maintain Temp May 10, 2015 01:58PM |
Re: Bed Heater Maxing Out and Unable to Maintain Temp May 10, 2015 02:15PM |
Re: Bed Heater Maxing Out and Unable to Maintain Temp May 11, 2015 03:33PM |
Re: Bed Heater Maxing Out and Unable to Maintain Temp May 23, 2015 05:25PM |
Re: Bed Heater Maxing Out and Unable to Maintain Temp June 02, 2015 12:00AM |
Re: Bed Heater Maxing Out and Unable to Maintain Temp June 02, 2015 03:24AM |
Re: Bed Heater Maxing Out and Unable to Maintain Temp June 02, 2015 03:44AM |
Re: Bed Heater Maxing Out and Unable to Maintain Temp June 15, 2015 10:34AM |
