Perimeter thickness is not constant April 29, 2015 05:37AM |
Re: Perimeter thickness is not constant April 29, 2015 07:43AM |
Re: Perimeter thickness is not constant April 29, 2015 07:55AM |
I thought this thing was different from regular Z wobble. Check the attached image (:Quote
the_digital_dentist
Congratulations! You have rediscovered "Z wobble". Please see the article here: [reprapmagazine.com] on page 29.
Re: Perimeter thickness is not constant April 29, 2015 01:48PM |
Re: Perimeter thickness is not constant April 30, 2015 04:27PM |
Re: Perimeter thickness is not constant May 01, 2015 11:48AM |
Re: Perimeter thickness is not constant May 01, 2015 02:17PM |
Re: Perimeter thickness is not constant May 01, 2015 03:30PM |
Re: Perimeter thickness is not constant May 01, 2015 09:32PM |
Re: Perimeter thickness is not constant May 01, 2015 09:36PM |
FalloutBe
I tested with another slicer but the result is the same.
I think my z rods are indeed rotating with more and less resistance every time they make a turn. I tightened the belt, hoping to reduce that effect, but now some part broke and I can't print another, CRAP!
You can see the broken plastic part, the ring around the bearing which prevents the belt from slipping off :/
So basically, the belt goes around the 4 corners, making the 4 rods rotate. The 4 rods are held in place by two axial bearings at the top, which *should* make sure they can't move up or down.
Do you think the whole idea; how I created the Z axis, is wrong? Or should I be able to fix this problem?
Re: Perimeter thickness is not constant May 02, 2015 06:25AM |
Kind of freely, but not entirely. I used to use M5 nuts to get some tiny pressure on the axial bearings.Quote
chris33
is the m5 captive at the top they freely to move. if not id try use a lead screws instead
Oh that is so kind of you to suggest that! (:Quote
Chris Rap
What part broke - surely one of us could print and send out a spare if its beyond your ability to make another. Or glue it back together - glue works wonders.
Re: Perimeter thickness is not constant July 04, 2015 11:59AM |
