cura vs slic3r with almost the same settings May 05, 2015 08:23PM |
Re: cura vs slic3r with almost the same settings May 06, 2015 06:47AM |
Re: cura vs slic3r with almost the same settings May 06, 2015 05:09PM |
Re: cura vs slic3r with almost the same settings May 07, 2015 09:15AM |
I too have 1.2 on shell thickness, only thing different i have is the width, i cannot seem to find where to set it to 0.4 (I can only find first line width)Quote
chris33
i found that cura width setting should match the nozzle ie 0.4 nozzle 0.4 width, so i e 1.2 mm perimeter would give me 3 where as slicer i can say i want 3 perimeters
Re: cura vs slic3r with almost the same settings May 07, 2015 01:06PM |
Re: cura vs slic3r with almost the same settings May 07, 2015 01:58PM |
So , you're using cura...what errors on dimensions are you getting?Quote
chris33
i can't either i just assumed that trying to print either wider than nozzle or thinner just complicates things, because i print in slicer with 0.4 nozzle 0.4 layer height but cura doesn't like 0.4 it comes up a side note when trying 0.3 lower i prefer cura though faster slicer better quality prints
Re: cura vs slic3r with almost the same settings May 07, 2015 02:11PM |
Re: cura vs slic3r with almost the same settings May 07, 2015 08:50PM |
Re: cura vs slic3r with almost the same settings May 08, 2015 08:59AM |
Re: cura vs slic3r with almost the same settings May 08, 2015 12:32PM |
Re: cura vs slic3r with almost the same settings May 08, 2015 03:09PM |
Re: cura vs slic3r with almost the same settings May 08, 2015 07:13PM |
