McMaster-Carr spring order to Canada fail May 08, 2015 01:01PM |
Re: McMaster-Carr spring order to Canada fail May 10, 2015 06:06AM |
Re: McMaster-Carr spring order to Canada fail May 10, 2015 12:30PM |
Ecky
Vanbot:
Saw a guy selling aluminum hot beds and using some rubber/ silicone tubing as a spring. Go to a hobby shop that sells gas model airplane engines and buy a piece of large size silicone tubing and cut it to the length of the spring you want to buy. Or go online and order from Great Hobbies, Silicone tubing. I am suggesting silicone as it is heat resistant. Rubber would probably work as well.
Re: McMaster-Carr spring order to Canada fail May 10, 2015 11:12PM |
Re: McMaster-Carr spring order to Canada fail May 11, 2015 10:16PM |
Ecky
Have a look here. In this case the supplier had his own tubing. The tubing I am suggesting is the large diameter, 1/8" ID, one. Car parts places will certainly have a rubber, neoprene, version as well.
I am cautious about proximity sensors as they don't react to glass as well a metallic surface. Perhaps it would be best to kill 2 birds with one stone and buy the above mentioned kit and get the rubber springs too.
Re: McMaster-Carr spring order to Canada fail May 14, 2015 01:13AM |
Re: McMaster-Carr spring order to Canada fail May 14, 2015 06:12AM |
