Nozzle blocks at the exact same point in the print May 09, 2015 08:34AM |
Re: Nozzle blocks at the exact same point in the print May 09, 2015 03:45PM |
Re: Nozzle blocks at the exact same point in the print May 09, 2015 04:55PM |
Re: Nozzle blocks at the exact same point in the print May 10, 2015 04:19AM |
Re: Nozzle blocks at the exact same point in the print May 10, 2015 05:20PM |
Re: Nozzle blocks at the exact same point in the print May 10, 2015 07:25PM |
Re: Nozzle blocks at the exact same point in the print May 11, 2015 03:29AM |
Ben.folkes
I've just done a test on a large perimeter as you say and it printed fine but it's on this print specifically at the same layer. I've resliced it and it hasn't helped. The 3d model has a section where two extruded objects intersect each other as it was the easiest way to design it so I was wondering if the fact there are overlaps in the stl make a difference?
Thanks for the help so far
Re: Nozzle blocks at the exact same point in the print May 11, 2015 10:42AM |
Re: Nozzle blocks at the exact same point in the print May 11, 2015 02:49PM |
Re: Nozzle blocks at the exact same point in the print May 11, 2015 03:14PM |
