So I've removed the extruder/hotend assembly, mainboard, control interface, filament sensing system, limit switches, and extruder/axis motors from a 3d Systems Cube X duo.
I replaced the axis motors with Kysan 1124192 steppers and attached the necessary pullies.
I've installed a 3mm 24v Pico hotend.
I've removed the Azteeg x3 controller board from my bukobot and installed it.
I've installed the stepper motors as shown in the pic below. Continuity testing to confirm wiring.
continuity confirmed positive from orange azteeg terminal 1 to orange motor connector 1
continuity confirmed positive from orange azteeg terminal 2 to orange motor connector 2
continuity confirmed positive from orange azteeg terminal 3 to orange motor connector 3
continuity confirmed positive from orange azteeg terminal 4 to orange motor connector 4
continuity between 1 and 2 for orange on board to board / board to motor and then also between 3 and 4 confirmed positive when the motor is connected.
continuity between 1 and 3 for orange on board to board / board to motor and then also 1 and 4 confirmed negative when the motor is connected.
continuity between 2 and 3 for orange on board to board / board to motor and then also 2 and 4 confirmed negative when the motor is connected.
continuity confirmed positive from red azteeg terminal 1 to orange motor connector 1
continuity confirmed positive from red azteeg terminal 2 to orange motor connector 2
continuity confirmed positive from red azteeg terminal 3 to orange motor connector 3
continuity confirmed positive from red azteeg terminal 4 to orange motor connector 4
continuity between 1 and 2 for red on board to board / board to motor and then also between 3 and 4 confirmed positive when the motor is connected.
continuity between 1 and 3 for red on board to board / board to motor and then also 1 and 4 confirmed negative when the motor is connected.
continuity between 2 and 3 for red on board to board / board to motor and then also 2 and 4 confirmed negative when the motor is connected.
continuity confirmed positive from blue azteeg terminal 1 to orange motor connector 1
continuity confirmed positive from blue azteeg terminal 2 to orange motor connector 2
continuity confirmed positive from blue azteeg terminal 3 to orange motor connector 3
continuity confirmed positive from blue azteeg terminal 4 to orange motor connector 4
continuity between 1 and 2 for blue on board to board / board to motor and then also between 3 and 4 confirmed positive when the motor is connected.
continuity between 1 and 3 for blue on board to board / board to motor and then also 1 and 4 confirmed negative when the motor is connected.
continuity between 2 and 3 for blue on board to board / board to motor and then also 2 and 4 confirmed negative when the motor is connected.
Now, I've wired up my AC socket. N to pin 3 on LED rocker switch, L to pin 2, and G the Ground on the powersupply. Switch pin 3 to N on power supply, pin 2 to L on power supply and, as mentioned previously, ground on power supply to the G on the AC recepticle.
The azteeg comes on when the rocker switch is switched.
Com port appears in printer settings and printer sucessfully connects. Repetier shows:
Hotend instructed to heat. No thermistor reading. Hotend does not heat.
Manual axis motion of all 3 axis is unresponsive.
Power off. Contiuity confirmed positive between 1,2,3,4 of orange, red, and blue. All stepper motor terminals. All motor connectors.
Continuity confirmed positve from 1,2,3,4 of orange, red, and blue (all stepper motor terminals and motor connectors) and frame rails.
Power supply disconnected from azteeg.
What the heck?!
See complete history of work searching istagram hashtag:
#cubelobotomy
