Extruder motor not turning
Posted by bonze77
July 19, 2015 07:02AM
The extruder motor moves from side to side (like vibrating) but doesn't turn fully.
The step stick is fine and the motor is fine.
It is a geared extruder and hasn't printed anything yet.
I am using marlin and have included my config file.
Help appreciated
open | download - Configuration.h (39.1 KB)
Re: Extruder motor not turning
July 19, 2015 08:04AM
bonze77
Help appreciated
Take a look at this thread: [forums.reprap.org]
July 19, 2015 11:14AM
How do you know the stepper is fine? Does it work on a different port?
If so, then try to run the stepper without the gear for test. If it spins, then:
the friction of the gears is to high or
the current setting ( Vref) is to low or
the jumpers on the extruder port have bad contact.
-Olaf
July 21, 2015 06:27PM
Broken wire -_-
