Z endstop inconsistant
July 22, 2015 06:28PM
Was having issues with consistant Z positioning so I snapped off the little metal arm. Now the button gets depressed directly. Seems to have solved the problem. Thought you guys would like to know.
Re: Z endstop inconsistant
July 22, 2015 07:38PM
Those little springy levers combined with the internal mechanical hysteresis of the switch itself make zeroing a very imprecise process. Pushing on the little nub on the switch is better. I recently switched from that to an optical Z endstop and find there is no hysteresis, so setting it is very easy and precise- no turn-until-it-clicks-then-back-off-1/4-turn type nonsense.
Edited 1 time(s). Last edit at 07/22/2015 08:45PM by the_digital_dentist.
July 23, 2015 12:35AM
It sounded like on previous posts that there were some issues with transients from the printer that can cause problems with some sensors. If you aren't seeing that do you mind giving a link to the sensor you are using. I would like to get one. Thanks.
July 23, 2015 12:53AM
I am using one removed from an Epson ink jet printer.
July 23, 2015 01:29AM
Thanks.
