Hesine i3 build instructions August 27, 2015 09:32AM |
Re: Hesine i3 build instructions August 27, 2015 10:15AM |
Re: Hesine i3 build instructions September 01, 2015 02:39PM |
Re: Hesine i3 build instructions September 03, 2015 12:55PM |
Re: Hesine i3 build instructions September 23, 2015 04:26PM |
Re: Hesine i3 build instructions September 25, 2015 01:01AM |
Re: Hesine i3 build instructions October 07, 2015 11:07AM |
Hesine i3 October 21, 2015 12:50PM |
Re: Hesine i3 November 03, 2015 11:30AM |
Re: Hesine i3 build instructions December 01, 2015 01:33AM |
Re: Hesine i3 build instructions December 30, 2015 01:28PM |
Re: Hesine i3 build instructions January 01, 2016 02:23PM |
Re: Hesine i3 build instructions January 05, 2016 08:02AM |
Re: Hesine i3 build instructions January 05, 2016 02:48PM |
Re: Hesine i3 build instructions January 05, 2016 03:10PM |
Re: Hesine i3 build instructions January 05, 2016 04:02PM |
viper412
It sounds like your in the same boat as me and you have to flash your control board to put the firmware on it to make the printer work.
Everyone acts like it is some big secret and you just can't get a straight answer for any where. I took me a month to even start to figure the interface between the printer and the board and I still can't
upload the firm ware to the printer because I can't find someone who will give you an straight answer, on an error message I keep getting Good luck I hope you better luck then I'm having!!!!
Re: Hesine i3 build instructions January 05, 2016 04:33PM |
Re: Hesine i3 build instructions January 05, 2016 04:58PM |
Re: Hesine i3 build instructions January 06, 2016 04:06AM |
Re: Hesine i3 build instructions January 07, 2016 02:54PM |
Re: Hesine i3 build instructions January 07, 2016 04:00PM |
wojo24
Got a new control board and not things are running. New problem is that the right z-axis thread keeps getting stuck while the right continues to turn. There is a slight wobble on the left but not huge. Would an adjustment to the current fix this or is there something else? Thanks.
Re: Hesine i3 build instructions March 15, 2016 12:31AM |
Re: Hesine i3 build instructions June 01, 2016 11:58AM |
hobby16
I bougth the same printer to the same vendor. Even if the manual pdf was on the SDCard (my case, not yours), it's very incomplete. Some details, for example about the belt mouting on X & Y axis, wiring placement, end stops... are badly missing from the pictures.
Then there is the configuration of the softwares (Repetier-Host and Slic3r), there is no information either.
Jack the vendor has been very responsive, I regret I did not contact him first, which made me waste a lot of time on trials and error.
What you will get from him is his shared dropbox account, you'll find the manual and a lot more pictures, look at them first to have the needed instructions. And also some screen captures of configuration parameters of the softwares. So bad you must ask to have them so I post it here
ID:[email protected]
Password: 89378800
All in all, I am very satisfied with the printer (just started my venture into the 3D printing world this week !), so happy I've ordered a second one from the same vendor. I spend more than one day to mount the first one, hope it will be much faster next.
Re: Hesine i3 build instructions June 02, 2016 11:44PM |
