Auto bed leveling marlin - Z probe offset does nothing? September 23, 2015 03:04PM |
Re: Auto bed leveling marlin - Z probe offset does nothing? September 23, 2015 06:53PM |
Re: Auto bed leveling marlin - Z probe offset does nothing? September 24, 2015 04:08AM |
Re: Auto bed leveling marlin - Z probe offset does nothing? September 24, 2015 05:34AM |
Re: Auto bed leveling marlin - Z probe offset does nothing? September 24, 2015 10:21AM |
Re: Auto bed leveling marlin - Z probe offset does nothing? September 24, 2015 01:01PM |
Re: Auto bed leveling marlin - Z probe offset does nothing? September 27, 2015 01:48AM |
Re: Auto bed leveling marlin - Z probe offset does nothing? September 27, 2015 02:35AM |
Re: Auto bed leveling marlin - Z probe offset does nothing? September 28, 2015 01:57PM |
Re: Auto bed leveling marlin - Z probe offset does nothing? September 29, 2015 03:22AM |
define min_software_endstops false-Olaf
Re: Auto bed leveling marlin - Z probe offset does nothing? September 29, 2015 10:04AM |
Re: Auto bed leveling marlin - Z probe offset does nothing? September 29, 2015 03:31PM |
Re: Auto bed leveling marlin - Z probe offset does nothing? September 30, 2015 08:10AM |
Re: Auto bed leveling marlin - Z probe offset does nothing? February 13, 2016 10:54AM |
Re: Auto bed leveling marlin - Z probe offset does nothing? August 27, 2016 07:05AM |
Re: Auto bed leveling marlin - Z probe offset does nothing? August 31, 2016 11:38PM |
Re: Auto bed leveling marlin - Z probe offset does nothing? October 28, 2016 06:57AM |
Re: Auto bed leveling marlin - Z probe offset does nothing? October 28, 2016 07:28AM |
Re: Auto bed leveling marlin - Z probe offset does nothing? October 28, 2016 06:17PM |
Re: Auto bed leveling marlin - Z probe offset does nothing? October 28, 2016 09:05PM |
Re: Auto bed leveling marlin - Z probe offset does nothing? October 29, 2016 01:33AM |
Re: Auto bed leveling marlin - Z probe offset does nothing? November 05, 2016 05:53PM |
McSquid
SUCCESS! My solutions archived below in 1 post to help others with future troubleshooting
Using a combination of the above advice from these great reprappers I now have the Z probe respecting the Z offset value. Here is what I ended up doing:
I left define min_software_endstops on but changed the way I compensated (realizing my previous method was stupid. changes below)
I changed my Z max height to the proper height (Bed = 0)
I changed my Z min height to -3 to allow the printer to go up to 3mm below 0. In theory software endstops + my 5mm bed springs should still prevent a (major) crash from LCD or pronterface controls
I printed a new mount for my sensor that was 1mm closer (so my target offsets were in the 1.2 - 1.7mm range instead of 0.2 - 0.7mm
I enabled the EEPROM as discussed earlier (still necessary to post for archiving solutions)
I used my LCD to set the offset instead of firmware : [control> motion> z offset] followed by [control> Store settings] (though I will still change firmware in future in case EEPROM defaults get loaded for any reason)
For additional clarification since this can be confusing: on the LCD menu a positive number is used for your probe offset. Mine is now 1.2mm. My probe activates 1.2mm before my nozzle hits the bed. Raising this number to 1.5mm will put my nozzle .3mm CLOSER to the bed. [0mm-----------<-Farther away-<--------1mm------------>-Closer-> ----------2mm] (nozzle in relation to bed)
Thanks everyone!
Re: Auto bed leveling marlin - Z probe offset does nothing? November 08, 2016 01:34PM |
Re: Auto bed leveling marlin - Z probe offset does nothing? November 08, 2016 03:53PM |
Re: Auto bed leveling marlin - Z probe offset does nothing? November 27, 2016 01:30PM |
Re: Auto bed leveling marlin - Z probe offset does nothing? November 27, 2016 04:04PM |
Re: Auto bed leveling marlin - Z probe offset does nothing? November 28, 2016 02:17PM |
cederron
So digging in the code ( I'm using Marlin RC7 ) trying to find the root of the problem, I found this line in marlin_main.cpp:
planner.buffer_line(destination[X_AXIS], destination[Y_AXIS], destination[Z_AXIS], destination[E_AXIS], MMM_TO_MMS(fr_mm_m), active_extruder);
I changed it to :
planner.buffer_line(destination[X_AXIS], destination[Y_AXIS], destination[Z_AXIS] - zprobe_zoffset, destination[E_AXIS], MMM_TO_MMS(fr_mm_m), active_extruder);
And now the z offset is respected...
A bug in Marlin? Misconfiguration in my config? Dont know.
Anyway this "bruteforce" resolves it.
