Cleaning Extruder with 12v Power Supply October 05, 2015 01:17PM |
Re: Cleaning Extruder with 12v Power Supply October 05, 2015 02:17PM |
Re: Cleaning Extruder with 12v Power Supply October 05, 2015 02:46PM |
frankvdh
Just to clarify nomenclature... The brass nozzle screws into the heater block. The heat break screws into the heater block from the top. The heat sink screws onto the heat break. The heater cartridge goes into a hole in the side of the heater block, held in place by a grub screw.
Generally speaking, you should screw/unscrew the nozzle whilst the heater block is hot, because there will be plastic in the threads which will make things difficult if it is solid.
It would be a bad idea to hook the heater cartridge directly up to the 12V supply... this would get very hot very fast. If you have a PTFE liner, it will probably be damaged.
To clear clogs, I sometimes remove the heat sink, then turn on the heater (still under control of the Marlin software) to 250C. This heats the whole of the heat break to melt any plastic anywhere in it. A piece of wire can then be pushed through the heat break to push out any plastic stuck in there. If you're careful, the PTFE liner will survive this process, but be prepared with a replacement.
The proper technique for reassembly is to heat the heater block, screw the nozzle all the way in, then back it out 1 turn. Now screw the heat sink onto the heat break, and screw the heat break all the way into the heater block (finger-tight... the heat break isn't strong), and tighten the nozzle into the heater block. This should seal the nozzle against the heat break, inside the heater block.
Re: Cleaning Extruder with 12v Power Supply October 05, 2015 03:32PM |
Re: Cleaning Extruder with 12v Power Supply October 05, 2015 07:58PM |
Re: Cleaning Extruder with 12v Power Supply October 06, 2015 12:06AM |
Re: Cleaning Extruder with 12v Power Supply October 06, 2015 02:15PM |
reifsnyderb
Hello,
Normally, PLA is burned out with a torch if you can't clear it any other way.
Also, for re-assembly, you need to remove that small tube that goes through the hollow set-screw in the top. (It should pull out with a small pointed pick of some sort. I use dental picks.) Then, the hollow set-screw can be used to adjust the ptfe liner tension. The small tube is then pushed back through the hollow set-screw.
So, to assemble it, you first need to put ptfe tape on the threads. Next screw the brass nozzle into the PEEK nozzle holder unti it is snug.
Since the hot-end was used, I would install the heater and thermistor then bring it up to temperature for a 5 minutes or so. Then, you should be able to ensure that the hollow set-screw is snug. If the hollow set-screw is not used to push the ptfe liner against the brass, the hot-end will fail. After the hollow set-screw is set, you can put the small guide tube back through the hollow set-screw.
Oh, yeah, that is a geniune J-Head hot-end made by me.
Best Regards,
Brian
Re: Cleaning Extruder with 12v Power Supply October 06, 2015 07:04PM |
Re: Cleaning Extruder with 12v Power Supply October 08, 2015 12:10PM |
Re: Cleaning Extruder with 12v Power Supply October 08, 2015 10:11PM |
Re: Cleaning Extruder with 12v Power Supply October 09, 2015 05:12PM |
When you re-tapped the hobbed bolt you may have lowered the diameter of the hobbed bolt, which in turn lowers the circumference and mm extruder per rotation. Re calibrate the extruder steps per mm.Quote
I have another question though. If I calibrated my extruder for 100mm of PLA, then why should I have to increase the flow percentage to get it to fill properly? Before I started having these problems my flow percentage was 100 percent with no problems.
