Step motors running funny.
Posted by GAZ082
October 15, 2015 09:54PM
Hello there. I'm testing the control modules and the step motors and found the two i plugged in so far are running funny, check the vid:
[www.youtube.com]
I loaded the test program. If i test the steppers on each connection, works fine. I believe there was a misconnection in one, pressed a little bit, solved. Now i try both at the same time, and what's on the vid happens.
Tips?
Thanks!
Re: Step motors running funny.
October 16, 2015 12:26AM
The fault were lousy connections to the pololus.
