pazza
kossel mini with
Rich Cattell Marlin v 1.04
does anybody know how to set the z probe proximity senor to probe the whole bed and not the just half of it
please
// Diameter of print bed - this is used to set the distance that autocalibration probes the bed at.
#define BED_DIAMETER 180 // mm
This is how big the bed is and it lets the printer know to stay within this.
If you have a low number it will not reach the outside of the bed.
#define AUTOLEVEL_GRID 20 // Distance between autolevel Z probing points, should be less than print surface radius/3.
This is how far apart from the center the points are in mm.
So if you have a low number as 3 or 5. It will only probe in the center of the bed.
If you have a high number like 50. It will try to probe off the bed.
So adjsut these settings and try again.
IF all else fails post a video so we can see what is really happening
