1st time printing ABS - heated bed not reaching 110ºC gets to 105-107ºC - January 01, 2016 12:23PM |
Re: 1st time printing ABS - heated bed not reaching 110ºC gets to 105-107ºC - January 01, 2016 05:12PM |
Admin Registered: 13 years ago Posts: 7,007 |
Re: 1st time printing ABS - heated bed not reaching 110ºC gets to 105-107ºC - January 02, 2016 12:59AM |
Re: 1st time printing ABS - heated bed not reaching 110ºC gets to 105-107ºC - January 02, 2016 01:06AM |
Re: 1st time printing ABS - heated bed not reaching 110ºC gets to 105-107ºC - January 02, 2016 01:21AM |
Re: 1st time printing ABS - heated bed not reaching 110ºC gets to 105-107ºC - January 02, 2016 01:27AM |
Re: 1st time printing ABS - heated bed not reaching 110ºC gets to 105-107ºC - January 02, 2016 02:07AM |
Re: 1st time printing ABS - heated bed not reaching 110ºC gets to 105-107ºC - January 02, 2016 02:12AM |
Re: 1st time printing ABS - heated bed not reaching 110ºC gets to 105-107ºC - January 02, 2016 02:33AM |
Re: 1st time printing ABS - heated bed not reaching 110ºC gets to 105-107ºC - January 02, 2016 02:40AM |
Re: 1st time printing ABS - heated bed not reaching 110ºC gets to 105-107ºC - January 02, 2016 09:04AM |
Re: 1st time printing ABS - heated bed not reaching 110ºC gets to 105-107ºC - January 02, 2016 09:31AM |
the_digital_dentist
The reason it takes almost forever to get close to your target temperature is simply that there is not enough power going into the heater. Insulating the underside of the platform will help a little, but you'll still be waiting forever for the bed to heat up to print temperature. If it takes a long time to get the bed up to temperature the PID controller will have a hard time regulating the temperature. Right now you're operating at the limit of the heater's performance. That's never a good place to be operating anything. You want to have some margin. What you really need to do is increase the voltage to the heater or use a heater rated for higher power at the voltage you're using. That may require changing the heater or the power supply or both.
Some power supplies have adjustable output voltage. If yours does you can crank the voltage up a couple volts and your problem may be solved, but be careful not to exceed the power rating of the power supply or the voltage rating of your controller board or whatever else is connected to that supply.
Re: 1st time printing ABS - heated bed not reaching 110ºC gets to 105-107ºC - January 02, 2016 10:10AM |
Re: 1st time printing ABS - heated bed not reaching 110ºC gets to 105-107ºC - January 02, 2016 12:57PM |
Re: 1st time printing ABS - heated bed not reaching 110ºC gets to 105-107ºC - January 02, 2016 02:20PM |
the_digital_dentist
12V is 12V. It doesn't matter if it comes from a 20A supply or a 300A supply. If the voltage is the same, the heater will deliver the same amount of heat. You need to increase voltage by a few volts or get a higher powered 12V heater. If you get a higher powered heater you may also need a higher power rated power supply, and you may have to check the current limit of the controller circuit board and the MOSFET that is used to switch power to the heater.
The power supply you are using is rated for 240W (12V x 20A= 240 W). The heater is rated for much less than that, though there's no spec on the amazon page saying exactly what it is. Based on my experience with my printer (about 300mm x 300mm bed size, 450W heater, 105C in about 5 minutes), I would say you need about 250W to get your bed up to print temperature in a reasonable amount the same time. Neither the heater nor the power supply are adequately rated to do that.
There's something else you should be aware of. You're intending to print with ABS, so you're trying to push the bed temperature up to 105-110C. That will get the first layer to stick just fine if the bed has the right surface covering, but it won't prevent parts from warping and delaminating. If you want to print ABS without those problems, the printer needs to be enclosed and the temperature inside the enclosure needs to be 45-50C. If you don't enclose the printer and get the temperature up, your prints will fail. Here's an illustration of what happens with and without an enclosure- guess which part was printed in an enclosed printer with a warm build chamber:
Re: 1st time printing ABS - heated bed not reaching 110ºC gets to 105-107ºC - January 02, 2016 06:53PM |
Re: 1st time printing ABS - heated bed not reaching 110ºC gets to 105-107ºC - January 03, 2016 04:20AM |
Re: 1st time printing ABS - heated bed not reaching 110ºC gets to 105-107ºC - January 03, 2016 04:47AM |
the_digital_dentist
Re: 1st time printing ABS - heated bed not reaching 110ºC gets to 105-107ºC - January 03, 2016 05:31AM |
David J
the_digital_dentist
Perhaps you're missing my point - or perhaps I didn't explain myself very well - I was wondering if the power supply was failing to supply 12v at the full load, or whether some electrical shortcoming was stopping the full 12v reaching the heatbed.
If I was in the OP's shoes, I'd do the following:
1. Put a multimeter across the power supply when everything is on - heatbed, hot end, the lot. If the meter shows 12v the the power supply is good enough, if the voltage has dropped then the supply is inadequate.
2. If the supply is good, I would put the meter across the terminals of the heatbed and try to reach 110C. It should show something very close to 12v, but if it doesn't then there's some problem between the power supply and the heatbed.
3. If there's 12v at the heatbed, then I would try insulation underneath - as many have already done. I have 2 layers of 2mm cork under my aluminium Mk3 heatbed, with another aluminium plate under that to keep it all together. Any heat-resistant insulation would do.
4. To help things along I would also put a sheet of corrugated cardboard on top of the bed while it's heating up.
Steps 3 & 4 have already been suggested previously; with these I can get my heatbed up to 110C in about 10 minutes or so. This isn't as quick as a more powerful heater would do it, but I'm in no great hurry.
As for PETG - I have no experience with it, but I have done some research and plan to buy a reel fairly soon. The main benefit seems to be that the heatbed only needs to be at around 50 - 60C, which will solve at least one of the OP's problems. The only down-side of PETG is availability and cost, in the UK anyway. There are very few stockists compared to PLA and ABS.
Re: 1st time printing ABS - heated bed not reaching 110ºC gets to 105-107ºC - January 03, 2016 05:58AM |
dougal1957
If you want PETG in the UK at a reasonable price then RepRapWorld in Holland do the ESUN Petg at 19 Euros per kilo Plus VAT works out at around £16.5 per kG plus the carriage. They are a very reputable company and they dispatch very quickly stuff normally arrives within the Week from time of order.
Doug
Re: 1st time printing ABS - heated bed not reaching 110ºC gets to 105-107ºC - January 03, 2016 05:59PM |
Re: 1st time printing ABS - heated bed not reaching 110ºC gets to 105-107ºC - January 04, 2016 03:57AM |
Re: 1st time printing ABS - heated bed not reaching 110ºC gets to 105-107ºC - January 04, 2016 04:26AM |
Re: 1st time printing ABS - heated bed not reaching 110ºC gets to 105-107ºC - January 04, 2016 06:18AM |
dc42
That's not my experience at all. I never did solve the stringing problems with ABS, but my very first print with PETG was nearly perfect. Using transparent PETG from Rigidink.
Re: 1st time printing ABS - heated bed not reaching 110ºC gets to 105-107ºC - January 07, 2016 04:23PM |
David J
1. Put a multimeter across the power supply when everything is on - heatbed, hot end, the lot. If the meter shows 12v the the power supply is good enough, if the voltage has dropped then the supply is inadequate.Quote
the_digital_dentist
Re: 1st time printing ABS - heated bed not reaching 110ºC gets to 105-107ºC - January 07, 2016 04:37PM |
Re: 1st time printing ABS - heated bed not reaching 110ºC gets to 105-107ºC - January 08, 2016 12:17AM |
Re: 1st time printing ABS - heated bed not reaching 110ºC gets to 105-107ºC - January 08, 2016 06:22AM |
Re: 1st time printing ABS - heated bed not reaching 110ºC gets to 105-107ºC - January 08, 2016 08:31AM |
Re: 1st time printing ABS - heated bed not reaching 110ºC gets to 105-107ºC - January 08, 2016 08:37AM |
