Setting home position... January 23, 2016 03:10AM |
Re: Setting home position... January 23, 2016 03:32AM |
Admin Registered: 13 years ago Posts: 7,005 |
Re: Setting home position... January 23, 2016 03:45AM |
Re: Setting home position... January 23, 2016 06:34AM |
Re: Setting home position... January 23, 2016 01:04PM |
Re: Setting home position... January 23, 2016 07:32PM |
Re: Setting home position... January 23, 2016 09:13PM |
That would normally be the case. I had to reverse my y axis to put the y min stop at the back of the machine. And then I reversed the y axis firmware.Quote
Dust
Yes in this case, but remember that this machine homes to X=200 (or what ever the X length is), Y=0, Z=0
(some people have the mind set that home is always X=0,Y=0,Z=0)
Re: Setting home position... January 24, 2016 04:51AM |
Re: Setting home position... January 24, 2016 05:25AM |
Re: Setting home position... January 24, 2016 05:37AM |
Re: Setting home position... January 24, 2016 05:50AM |
Re: Setting home position... January 24, 2016 05:59AM |
Re: Setting home position... January 24, 2016 06:03AM |
Re: Setting home position... January 25, 2016 04:33PM |
Re: Setting Print start position February 08, 2016 02:30AM |
Re: Setting home position... February 12, 2016 07:59PM |
Re: Setting home position... January 14, 2017 08:07PM |
But I really need this fixed as I can't print a bigger file that I need.Quote
start
echo:Marlin1.0.0
echo: Last Updated: Oct 31 2016 14:49:22 | Author: Zviper89, Migbot Stndrdauto lvl
Compiled: Oct 31 2016
echo: Free Memory: 3813 PlannerBufferBytes: 1232
echo:Hardcoded Default Settings Loaded
echoteps per unit:
echo: M92 X80.00 Y80.00 Z1600.00 E100.00
echo:Maximum feedrates (mm/s):
echo: M203 X225.00 Y225.00 Z3.00 E25.00
echo:Maximum Acceleration (mm/s2):
echo: M201 X2650 Y2650 Z100 E10000
echo:Acceleration: S=acceleration, T=retract acceleration
echo: M204 S2650.00 T3000.00
echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
echo: M205 S0.00 T0.00 B20000 X15.00 Z0.40 E5.00
echo:Home offset (mm):
echo: M206 X0.00 Y0.00 Z0.00
echoID settings:
echo: M301 P22.20 I1.08 D114.00
echoD card ok
Re: Setting home position... April 19, 2017 08:25PM |
