I3 X Belt Idler January 28, 2016 10:04PM |
Re: I3 X Belt Idler January 28, 2016 11:52PM |
Re: I3 X Belt Idler January 30, 2016 06:15AM |
Re: I3 X Belt Idler January 30, 2016 01:24PM |
DjDemonD
Ive ordered a bunch of toothed idlers for my printers very cheap [link] they should be slightly more accurate but I'm not sure they'll always be quieter.
Re: I3 X Belt Idler January 30, 2016 06:03PM |
Re: I3 X Belt Idler January 31, 2016 11:46AM |
Re: I3 X Belt Idler January 31, 2016 12:28PM |
Re: I3 X Belt Idler January 31, 2016 12:40PM |
Re: I3 X Belt Idler January 31, 2016 12:45PM |
Re: I3 X Belt Idler January 31, 2016 12:57PM |
Re: I3 X Belt Idler January 31, 2016 12:58PM |
Dirty Steve
Toothed idler pulleys won't remove your waves. It's caused by resonance in the stepper motor, that correlates to driver amperage, and motor rotation degrees per rotation.
I chased this issue for 2 years, toothed pulleys, flipped belts, yadda... Changed from 1.8 to 0.9 degree motors, and the wave pattern in my prints became half the size of the 1.8 motors. Regardless of microstepping, steppers have a higher 'torque' as it internally moves past it's 1.8 or 0.9 degree angle.
If you have ever hand turned one of your motors while under power, the single 'click' the motor moves is the motor going that 1.8 degree of rotation.
Also no difference in print pattern between 5mm and 2mm drive belts.
Re: I3 X Belt Idler January 31, 2016 01:04PM |
Re: I3 X Belt Idler January 31, 2016 02:16PM |
Re: I3 X Belt Idler January 31, 2016 04:26PM |
