Filament sensor January 31, 2016 12:29AM |
Re: Filament sensor January 31, 2016 03:42AM |
Admin Registered: 13 years ago Posts: 7,005 |
Re: Filament sensor January 31, 2016 11:27AM |
Dust
This already exists in firmware, you just need to enable it.
see [github.com]
The m600 is "M600 - Pause for filament change X[pos] Y[pos] Z[relative lift] E[initial retract] L[later retract distance for removal]"
All you need to do is add a sensor, the easiest being a switch type to the intake of the extruder. where the switch is held closed when the filament in entering the extruder (a simple loop on the switch arm that the filament goes threw would do it, a ptfe liner on the loop might also be a good idea to keep friction down)
Re: Filament sensor January 31, 2016 02:37PM |
Re: Filament sensor January 31, 2016 04:29PM |
