Technique for Printing ABS on Glass HB Glue Stick Juice February 01, 2016 03:07AM |
Re: Technique for Printing ABS on Glass HB Glue Stick Juice February 02, 2016 01:36AM |
Re: Technique for Printing ABS on Glass HB Glue Stick Juice February 02, 2016 02:31PM |
Re: Technique for Printing ABS on Glass HB Glue Stick Juice February 02, 2016 04:50PM |
Re: Technique for Printing ABS on Glass HB Glue Stick Juice February 05, 2016 12:06AM |
Re: Technique for Printing ABS on Glass HB Glue Stick Juice February 05, 2016 12:08AM |
Just apply back and forth to cover the whole bed. let it dry and apply another layer 90* off from the first layer. After that my ABS sticks no problem. I have to wait for the part and bed to cool to room temp before it will let go.Quote
to-the-nth
Floyd - Curious how do you apply the glue stick?
Re: Technique for Printing ABS on Glass HB Glue Stick Juice February 05, 2016 07:09AM |
JamesK - do you see any lift off at the edges of the part? On a fresh surface or one with only a few recoats, I am seeing absolute flat surfaces. I am sure this is putting tremendous stain on the glass, so I am going to add heaters to get the chamber to 50C. If you are doing prints that are not very tall, I think there is a heating affect from the bed that keeps the prints fairly warm without a chamber.
Re: Technique for Printing ABS on Glass HB Glue Stick Juice February 05, 2016 08:08AM |
Re: Technique for Printing ABS on Glass HB Glue Stick Juice February 05, 2016 08:34AM |
Re: Technique for Printing ABS on Glass HB Glue Stick Juice March 05, 2016 04:57PM |
JamesK
I haven't seen any lifting with abs, but I have had some problems with nylon, and with acetal I had to use both blue tape + glue stick. Agreed about the strain placed on the glass, I had a chip pull out on a bigger print. And yes, also agreed on taller prints being more prone to splitting than short ones - I really must get on with building an enclosure!
That corner to corner print you show is more extreme than anything I have tried, so it may be that I am just a few steps behind you and have yet to discover the limits.
Re: Technique for Printing ABS on Glass HB Glue Stick Juice March 05, 2016 05:56PM |
Re: Technique for Printing ABS on Glass HB Glue Stick Juice March 05, 2016 06:08PM |
What brand/color of ABS and glue stick?
The glue stick is Elmers purple.|
Re: Technique for Printing ABS on Glass HB Glue Stick Juice May 12, 2016 02:08AM |
Re: Technique for Printing ABS on Glass HB Glue Stick Juice May 12, 2016 07:09AM |
Jamesk - I tried test print of a large wade extruder gear using Elmers Washable School Glue Disappearing Purple, but got up turned edges and teeth. Is that the same Purple as you are using? What bed temp? at 90C the Purple seems soft an gooey.
Re: Technique for Printing ABS on Glass HB Glue Stick Juice May 12, 2016 07:45AM |
Re: Technique for Printing ABS on Glass HB Glue Stick Juice May 15, 2016 01:29AM |
Re: Technique for Printing ABS on Glass HB Glue Stick Juice May 15, 2016 02:18AM |
Re: Technique for Printing ABS on Glass HB Glue Stick Juice May 15, 2016 07:14AM |
Sounds like your bed w/Purple is well seasoned..."white, dry and slightly powdery." Maybe the glue really does have to cook to achieve full adhesion.
Re: Technique for Printing ABS on Glass HB Glue Stick Juice May 16, 2016 01:32AM |
Re: Technique for Printing ABS on Glass HB Glue Stick Juice May 16, 2016 10:35AM |
Re: Technique for Printing ABS on Glass HB Glue Stick Juice May 23, 2016 01:16AM |
Re: Technique for Printing ABS on Glass HB Glue Stick Juice May 23, 2016 06:59AM |
Re: Technique for Printing ABS on Glass HB Glue Stick Juice May 23, 2016 08:49AM |
Re: Technique for Printing ABS on Glass HB Glue Stick Juice May 23, 2016 10:31PM |
Re: Technique for Printing ABS on Glass HB Glue Stick Juice May 29, 2016 08:00PM |
Re: Technique for Printing ABS on Glass HB Glue Stick Juice May 29, 2016 08:10PM |
Re: Technique for Printing ABS on Glass HB Glue Stick Juice May 29, 2016 08:28PM |
Re: Technique for Printing ABS on Glass HB Glue Stick Juice June 04, 2016 01:54PM |
Re: Technique for Printing ABS on Glass HB Glue Stick Juice June 05, 2016 12:40PM |
Re: Technique for Printing ABS on Glass HB Glue Stick Juice June 07, 2016 09:49PM |
