My Journey to Build a Prusa i3 February 11, 2016 04:33PM |
Re: My Journey to Build a Prusa i3 February 12, 2016 02:44PM |
Re: My Journey to Build a Prusa i3 February 12, 2016 09:29PM |
Re: My Journey to Build a Prusa i3 February 14, 2016 12:37AM |
Re: My Journey to Build a Prusa i3 February 14, 2016 10:29PM |
JamesK
Hey, welcome to the forum. I got my i3-alike running earlier this year and I've been really enjoying it.
A few thoughts on your parts list...
A lot of the prices seem a little high. If you don't mind the longer shipping times (4 to 6 weeks) you can often get better prices on Aliexpress. Most of the parts for my build came from there and I haven't had any bad experiences yet.
msaeger
Don't forget screws those things add up if you have to buy them at the hardware store. I would order a bunch from banggood.com or aliexpress. You should check prices for the other parts on those sites too like James said. Make sure you have an old PCU that can supply enough power on the 12V rail. I just bought a 430 watt one today from Microcenter for 20 bucks that says it supplies 32 amps on the 12V rail. There were some with higher wattage total that had less current on the 12V rail.
I agree a old picture frame glass or 2 dollar sheet from the big box store is good enough save the money and buy lead screws instead of all thread.
Giantkiller
If you are in the USA Ace hardware has a wonderful selection of m3 and m4 threaded parts.
My Replikeo did not have a spring loaded heat bed so I went to ACE and added the springs and screws to do this.
Re: My Journey to Build a Prusa i3 February 15, 2016 12:03AM |
jandcando
I have a PCU from an old PC. It has 280 watts and 16 amps on the 12 volt rail. Is that enough?
Re: My Journey to Build a Prusa i3 February 15, 2016 01:39PM |
Re: My Journey to Build a Prusa i3 February 15, 2016 07:01PM |
Re: My Journey to Build a Prusa i3 February 15, 2016 07:57PM |
Re: My Journey to Build a Prusa i3 February 15, 2016 07:59PM |
msaeger
jandcando
I have been reading 20 but I don't really know for sure. I had several old ones too but none that claimed 20A on the 12V rail so I just bought a new one. 20 bucks for one that can do 32A and is silent even under load was a good deal.
Oh and if you decide to remove the extra wires don't be dumb like me and forget to leave a 5V set. I was planning on keeping one 5V set in case I ever want auto bed leveling and forgot.
Re: My Journey to Build a Prusa i3 February 15, 2016 08:07PM |
Giantkiller
Yep. I forgot that. Stick a 100k resistor from 5v red to ground black.
Or a 330 ohm in series with an LED. Cool power on indicator.
Re: My Journey to Build a Prusa i3 February 16, 2016 03:37AM |
// Select carriage lenght ****************************************************** // 30 for single carriage extruder (two holes with centers 30mm apart) // 50 for wade or single with fan (three holes, 30-20) // 80 for full length carriage (four holes, 30-20-30) carriage_l_base = 50;
Re: My Journey to Build a Prusa i3 February 16, 2016 06:50AM |
Re: My Journey to Build a Prusa i3 February 16, 2016 07:12AM |
Re: My Journey to Build a Prusa i3 February 16, 2016 09:16AM |
Re: My Journey to Build a Prusa i3 February 17, 2016 06:30AM |
Re: My Journey to Build a Prusa i3 February 17, 2016 07:16AM |
Re: My Journey to Build a Prusa i3 February 17, 2016 08:13AM |
JamesK
You might want to check around and see if anyone you know has an old pc that isn't being used and they are thinking of throwing away. A lot of the older power supplies with dual 12v rails work well.
If I didn't have spare PC psu's lying around, it would be a hard choice between spending money on a pc supply or getting a dedicated 12v psu. There are some nice points about having software control of the 12v, but it's a lot of work to make a PC psu into a tidy printer power supply.
Re: My Journey to Build a Prusa i3 February 17, 2016 08:25AM |
Re: My Journey to Build a Prusa i3 February 18, 2016 04:46PM |
Re: My Journey to Build a Prusa i3 February 19, 2016 06:37PM |
Re: My Journey to Build a Prusa i3 April 04, 2016 12:40AM |
Re: My Journey to Build a Prusa i3 April 04, 2016 02:33AM |
Re: My Journey to Build a Prusa i3 April 04, 2016 01:26PM |
Re: My Journey to Build a Prusa i3 April 05, 2016 03:32PM |
dc42
If the Smoothieboard is out of stock, have you considered the Duet? Like the Smoothieboard it is 32 bit with configuration of the motor currents done in software and all configuration done in a file on the SD card. But the firmware supports a much better web interface than the Smoothieboard including fast file upload to the SD card, also it supports extruder pressure advance.
chris33
for psu you can use a xbox 360 psu
Thanks for the info though! Maybe I can track down a friend who has one.
Re: My Journey to Build a Prusa i3 April 05, 2016 03:47PM |
dc42
Re: My Journey to Build a Prusa i3 April 05, 2016 04:32PM |
jandcando
dc42
It would appear that those are out of stock as well, at least from the official site. It looks like a great board, though! I'll keep tabs on both boards and see which one comes back in stock. I happen to know from IRC that the Smoothieboards will be back in stock in a couple weeks now. I'll really buy either one, but the Duet's price is very attractive. I'm going to research both options a bit more now.
Re: My Journey to Build a Prusa i3 April 05, 2016 09:22PM |
dc42
jandcando
dc42
Which part of the world are you in? T3P3 in the UK seem to be out of stock of the Duet, but Filastruder in the USA appears to have stock.
Re: My Journey to Build a Prusa i3 May 12, 2016 02:58AM |
