Need Help on Prusa Mendel
February 20, 2016 02:57AM
Hey guys,
I need your help.
I have a Prusa Mendel since few weeks (http://reprap.org/wiki/Prusa_Mendel/fr) and I have many troubles to print.
The first layers are good, but it gets worse and worse as and when it is printed and ended in a heap.
I don't understand why and how to correct this.
All I try ends horribly.
Many thanks for all things you could tell me.
Libfy
Re: Need Help on Prusa Mendel
February 21, 2016 01:32AM
What size nozzle, layer height, extrusion multiplier and temps. Pictures?
February 21, 2016 03:55AM
thanks for your reply.
Here are some pics.
Nozzle is 0.4mm
Filament: 3mm
For example, I tried to print this object just for test: [www.thingiverse.com]
Layer Height: 0.30
Infill%: 60
Temps: 200
The results are horrible and I am distraught:
Thanks for your help
February 22, 2016 07:39AM
Have you calibrated the extruder and set the nozzle size of 0.4mm in the slicer software ?
What was your set hot-end temperature set at?
Here are some links to information when setting up the printer and having problems with print quality.
[reprap.org]
[www.simplify3d.com]#
Supporting 3D Printers with Parts and Build services.
Printer: Ormerod 2 (528.4) Duel extruder set-up with Aluminium X-Rib, RRPro Firmware v1.11-ch (2016-04-08)
