Extracting firmware settings from printer
Posted by Stryker
February 29, 2016 10:37AM
Hello everyone!
I own a PrusaI3 printer with a Melzi board and I've been trying to add auto-leveling since I didn't want to waste anymore time doing it manually.
The problem is that since I bought the board with the software pre-installed I don't know the Marlin settings and I have to modify Configuration.h to enable auto-leveling.
I was wandering if it was possible to extract settings like PID, steps per mm, etc from the board to put into Marlin without doing all the measurements by hand since the printer works fine.
The reason why I'm trying not to do it from scratch is that I don't know the specifics for each part (belts, screws, gears, etc) since they arrived in the same box.
Thanks.
Re: Extracting firmware settings from printer
February 29, 2016 10:57AM
Have a look at the m codes you can use [reprap.org] like M360 M503 etc
February 29, 2016 05:07PM
Build a script set and see if you can push through a terminal program. Pronterface will give onesy twosey.
March 02, 2016 07:18AM
Frans@France
Thanks! That saved me a lot of time
Edited 1 time(s). Last edit at 03/02/2016 07:19AM by Stryker.
