Working Repetier Firmware 4 Cyclops/Ramps 1.4
March 18, 2016 02:19AM
Anyone have a working config (configuration.h) for a Ramps 1.4 running a dual extruder E3d Cyclops?
I figure if I get the tool settings working, I wan adjust the rest to work.
Current issue (and the LAST issue) is the hot end simply doesn't heat up. The same firmware, 2 seperate boards, 3 seperate hot ends, tested with multimeter and a fan (in addition to the hot ends), can't think of this being a hardware issue - the only thing that has changed is the firmware used.
Thanks in advance.
