mixing things up
Posted by asaf
mixing things up
November 09, 2010 06:29PM
hey everyone!
my y stepper motor driver board broke down so i ordered a new one.
my x and y stepper boards are 1.1 version and the new one is 2.3.
i tried to make everything work and found out that the new board requires enable pins to be inverted while the 1.2 version doesn't.
if i choose to invert the enable pins,only z axis work and if i don't, x and y axis work but z donesn't.
how do i make i all work together?
i'm using gen2electronics tring to build a darwin.
thanks for the help!
Re: mixing things up
November 09, 2010 06:54PM
I expect you could hack the firmware, but the simplest thing would be to let it control z and wire x & y so they are permanently enabled.
November 10, 2010 12:24AM
My motors (with Gen 2 electronics) are permanently enabled. It's not a big deal, and doesn't hurt anything.
November 10, 2010 04:00PM
thanks guys!
i made those adjustments and it works beautifully!
Edited 1 time(s). Last edit at 11/10/2010 04:01PM by asaf.
