Random extrusion gaps June 30, 2016 01:47PM |
Re: Random extrusion gaps June 30, 2016 11:45PM |
Re: Random extrusion gaps July 01, 2016 05:47AM |
dbrewski
I'm struggling to find a fix for a weird problem that has popped up. In the attached pictures, you can see that small gaps where it looks like it is under extruding. I have check my extrusion rate. I have done a bunch of cold pulls with nylon filament, I have adjusted temperature and tension on the filament. This filament is fairly fresh and has not spent too much time in exposed air. I am also having the same problem with ABS filament as well. Nothing seems to be making any difference in how my parts look. Any suggestions would be greatly appreciated. I also attached a picture of my set up. It is a direct drive with an e3d v6( I also replaced the PTFE to see it that was the problem)
Re: Random extrusion gaps July 01, 2016 10:55AM |
Re: Random extrusion gaps July 01, 2016 01:09PM |
Re: Random extrusion gaps July 02, 2016 04:38AM |
Re: Random extrusion gaps July 02, 2016 09:13AM |
Re: Random extrusion gaps July 05, 2016 02:19PM |
Re: Random extrusion gaps July 06, 2016 08:08AM |
