I'm having an issue homing the Z axis on my printer. The other two axis will home fine. When I turn on the printer, it assumes that it is at 0 on the Z axis. I can move the axis up and down but not below that arbitrary 0 point. When I home the Z axis, the motors hum for a second but don't turn. I've attached the config.h file. Thank you.
That did seem to make the problem better, but for some reason my printer is moving up when I tell it to home now. Changing the home dir seems to make the problem worse.
