Chunky Aluminium Profile Build July 08, 2016 11:56AM |
Re: Chunky Aluminium Profile Build July 09, 2016 09:39AM |
Re: Chunky Aluminium Profile Build July 09, 2016 10:16AM |
Re: Chunky Aluminium Profile Build July 09, 2016 10:20AM |
Re: Chunky Aluminium Profile Build July 09, 2016 10:26AM |
Re: Chunky Aluminium Profile Build July 09, 2016 04:24PM |
Re: Chunky Aluminium Profile Build July 09, 2016 04:28PM |
cozmicray
45mm beams on a 225mm span?
looks like build volume will only be 150 x 150 x 150 mm
Why not a bigger build area?
Will you be supporting a 1 ton extruder?
Re: Chunky Aluminium Profile Build July 09, 2016 05:19PM |
Re: Chunky Aluminium Profile Build July 10, 2016 07:53AM |
Re: Chunky Aluminium Profile Build July 10, 2016 09:36AM |
Re: Chunky Aluminium Profile Build July 10, 2016 11:08AM |
Re: Chunky Aluminium Profile Build July 10, 2016 03:58PM |
Digital_Dentist
The corner brackets are completely unnecessary in your printer. People use those for smaller cross section area extrusions because they can't be joined rigidly without them (or flat plates). You can tap the axial hole in the extrusion and use button head cap screws to bolt the pieces together
Re: Chunky Aluminium Profile Build July 12, 2016 08:53AM |
Re: Chunky Aluminium Profile Build July 12, 2016 09:06AM |
Re: Chunky Aluminium Profile Build July 12, 2016 09:22AM |
Re: Chunky Aluminium Profile Build July 12, 2016 09:24AM |
Re: Chunky Aluminium Profile Build July 12, 2016 09:33AM |
Re: Chunky Aluminium Profile Build July 12, 2016 09:38AM |
Re: Chunky Aluminium Profile Build July 12, 2016 09:42AM |
Re: Chunky Aluminium Profile Build July 12, 2016 09:45AM |
Re: Chunky Aluminium Profile Build July 14, 2016 02:37PM |
Re: Chunky Aluminium Profile Build July 14, 2016 02:44PM |
Re: Chunky Aluminium Profile Build July 14, 2016 03:09PM |
Re: Chunky Aluminium Profile Build July 16, 2016 04:11PM |
Re: Chunky Aluminium Profile Build July 20, 2016 12:17PM |
Re: Chunky Aluminium Profile Build July 23, 2016 12:37PM |
Re: Chunky Aluminium Profile Build July 25, 2016 02:54PM |
Re: Chunky Aluminium Profile Build July 25, 2016 03:58PM |
Re: Chunky Aluminium Profile Build July 25, 2016 06:09PM |
Admin Registered: 13 years ago Posts: 7,010 |
Re: Chunky Aluminium Profile Build July 26, 2016 02:28AM |
