Two Z-axis motors plus 3 extruder motors on Rumba board.
Posted by Lymphomaniac1
July 20, 2016 04:37PM
I am thinking of using my Rumba Board with my Diamond head on a Prusa I3. In addition to the three extruders, I intend to use 2 Z-axis motors. How do I hook up the two z-axis motors. My guess is that I twist my two black wires together, my two green wires together, my two red wires together and my two blue wires together, then insert each twisted wire pair into the appropriate terminal. Am I right? Do I need to change my DRV8825 amp settings any different to what I have on my RAMPS 1.4 board? Do I need to make any changes to my Marlin setup other than choosing the RUMBA board as my main board?
Thanks,
Stuart
Edited 1 time(s). Last edit at 07/20/2016 04:39PM by Lymphomaniac1.
Re: Two Z-axis motors plus 3 extruder motors on Rumba board.
July 20, 2016 06:33PM
Mine are wired in series as shown at [reprappro.com] . I've seen a number of cases where people have said wiring in parallel is problematic.
July 21, 2016 02:18AM
IMBoring25:
Thanks for your response.
Stuart
Edited 1 time(s). Last edit at 07/21/2016 02:22AM by Lymphomaniac1.
July 24, 2016 06:30PM
If possible, you should consider one Z motor and and belt and pulley setup. Much more repeatable leveling.
