Extruder/Nozzle Clogging Problem August 09, 2016 01:48PM |
Re: Extruder/Nozzle Clogging Problem August 09, 2016 03:11PM |
Re: Extruder/Nozzle Clogging Problem August 09, 2016 03:40PM |
Re: Extruder/Nozzle Clogging Problem August 09, 2016 04:40PM |
Re: Extruder/Nozzle Clogging Problem August 09, 2016 06:49PM |
Re: Extruder/Nozzle Clogging Problem August 09, 2016 10:28PM |
cagtag
If I print 10mm above the bed, there is no problem. I tried it.
Re: Extruder/Nozzle Clogging Problem August 11, 2016 04:08AM |
frankvdh
cagtag
OK, so the problem isn't in the extruder or hot-end.
What kind of printer do you have? How are you setting the nozzle height? Are you using auto-leveling?
How flat is your bed? ("Level" refers to the plane of the bed... it should be in the same plane as the nozzle moves. "Flat" refers to variations in the height of the bed surface above/below the plane).
Re: Extruder/Nozzle Clogging Problem August 11, 2016 10:05PM |
