Heat mat voltage September 05, 2016 07:07AM |
Re: Heat mat voltage September 05, 2016 05:30PM |
Re: Heat mat voltage September 06, 2016 03:38AM |
Re: Heat mat voltage September 06, 2016 07:28AM |
Re: Heat mat voltage September 07, 2016 05:06AM |
Re: Heat mat voltage September 07, 2016 05:30AM |
Re: Heat mat voltage September 07, 2016 07:43AM |
Re: Heat mat voltage September 07, 2016 08:03AM |
Re: Heat mat voltage September 08, 2016 08:04AM |
Re: Heat mat voltage September 08, 2016 12:06PM |
Amoniak
Well, in any case I'm not going to run the standard PCB heater + glass setup for many reason.
I rather go my intend way of silicon heater on a milled and casted alu plate with PEI.
Amoniak
If I were to go 24v, I think the best way would be to go all 24v.
Amoniak
In that case I would probably need to go 0.9 degree steppers as the drivers I will use is DRV8825'a and they are known for their high pitch noise when paired with 1.8 steppers @ 24v.
Amoniak
Problem I find is the availability of 0.9 stepper and the price compare to 1.8.
Amoniak
Is there any down side to use 0.9 steppers? Should I aim for the same Amp 1.5-1.7A?
